Old 08-31-2010, 08:03 PM   #1
Adony's Avatar
MaxxAir Vent cover Installation
I have two crank up type vents on my 2010 Wildwood... I installed a MaxxAir vent cover over the one in the bathroom as it was easy to accomplish from a step ladder at the rear of the trailer...now I want to install a second cover over the vent above the kitchen area BUT... it is located center line about 10 feet from the rear of the trailer... I can't reach the vent to drill the holes by just standing on a ladder... QUESTION... I am a large man and wonder if the roof will safely support me if I lie on it from the side to reach the vent and drill the holes then tighten the hardware??? Would it be best to place a piece of plywood on the roof to distribute the weight... Ideas?? Thoughts?? maybe I had better take it to the RV man to install it???
Adony is offline   Reply With Quote
Old 08-31-2010, 08:31 PM   #2
Dave_Monica's Avatar
First of all, if you have a factory ladder for access to the roof, it's labelled as to it's rating, 300lbs. As far as the roof itself, it's strong enough. I'm sure that when these are manufactured, there'll be more than one person of the roof at once. If you concerned, take a 4x4' piece of 1/2" plywood up there with you to distribute the load.
Dave
Old 08-31-2010, 08:59 PM   #3
It will hold you. Go by an RV repair shop sometime. There may be two or three people up on the roofs of some units when they are working on them. You can do as Dave suggested and put some plywood down to help distribute the load.
Hokiehall is offline   Reply With Quote
Old 09-01-2010, 07:11 AM   #4
3 Happy Campers's Avatar
I run about 250-260 lbs & have been on the roof of every RV we’ve owned without issue. Even the R-Vision.
If you haven’t purchased the second MaxxAir cover yet I recommend getting a MaxxAir II. They have a larger louvered area allowing more air flow & they are hinged so you can easily clean inside.
I got mine @ Amazon for a lot cheaper than the local shop or CW.
3 Happy Campers is offline   Reply With Quote
Old 09-01-2010, 08:13 PM   #5
backin15's Avatar
I am 225 and didn't go through my roof. If you are concerned go with the plywood. That would also give you something to place your tools on so you don't have to worry about damaging the roof.
I would also go with the MaxxAire II's. They move enough air so you can safely install them over a Fantastic Fan.
backin15 is offline   Reply With Quote
Old 09-03-2010, 04:12 PM   #6
MrT
MrT's Avatar
I have the Maxxair II's as well, and like them just fine. Others on this forum and elsewhere have expressed satisfaction with the Camco Aero-Flow vent covers.
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
Old 09-04-2010, 08:57 PM   #7
Lrt's just say I am over 300 pounds and the roof doesn't move when I walk on it!
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
jackhartjr is offline   Reply With Quote
Old 04-14-2014, 08:10 PM   #8
Watch when the dealer installs the Maxx air vents. Our dealer did not run the little bolts thru the aluminum vent cover sides. Instead they put wood screws thru the roof membrane beside the vents to hold the brackets down. \Now I cannot open the vent in the bath room and one of the others sticks when I crank it open. Don't know what they did with the 3/8 bolts to go on the uprights to go on the sides of the aluminum vent covers. over the
Now I have to go to the dealer and get the parts that came with the Maxx Airs as they sure do not use wood screws to fasten the brackets down. When I fix this I will have to fill the wood screw holds thru the roof membrane
installer was not to bright and should have followed the installation instructions or should have watched Mark Polk's video on installing them.
Brandon 2
brandon 2 is offline   Reply With Quote
Old 04-14-2014, 08:40 PM   #9
Phat Phrog Stunt Crew
elind's Avatar
When I was at the Rockwood plant last summer, 2-3 workers at a time running all over the roof. Here's a pic of whats in the roof. I'm over 300 lb and I go all over my LaCrosse roof.
ID:	49866   Click image for larger version
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 04-14-2014, 09:29 PM   #10
Steeljag's Avatar
You guys need some bikes.....lol ! Be careful up there.
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
