Old 10-01-2017, 09:26 AM   #1
Mirrors on the Legacy
Trying to replace the extension arm on my legacy. I've had to drill out 2 of the 3 retention screws. And it still won't let go. Any ideas? Click image for larger version
Mike Minshall is offline   Reply With Quote
Old 10-01-2017, 10:10 AM   #2
SeaDog's Avatar
have you tried using an easy out on the remaining threads to ensure it is free or a pick to pull the remains threads away from the body
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 10-01-2017, 10:43 AM   #3
That's what I'm trying next. Hoping that does it.
Old 10-01-2017, 11:01 AM   #4
SeaDog's Avatar
please let the forum know what worked so others can take advantage or your experience.
Retired Navy
Old 10-01-2017, 04:03 PM   #5
Ok end result. I drilled them out more and then beat with a hammer. Probably not the best or correct method but it did work. Now I've got to take off the 6 pin connector so I can fit the wire into the new arm. You need to remember to mark the wire placement in the connector. So once you rethread the wire you can put them back into the connector in the correct order.
Good times.
