Old 08-06-2019, 02:59 PM   #1
Missing chunk of underbelly cover
After working on another maintenance project, I noticed there is a chunk missing of the underbelly in my wheel well area. The underbelly of this Puma XLE 30DBSC appears to be more of a thin structureless plastic sheet than chamoplast.
I'm curious how I should try to properly repair this - what materials will stick well, etc, as I worry about the tires splashing up water onto the exposed wood above.
Thanks!
JayG7800 is offline   Reply With Quote
Old 08-06-2019, 04:21 PM   #2
A32Deuce's Avatar
Gorilla tape.
A32Deuce is offline   Reply With Quote
Old 08-06-2019, 04:23 PM   #3
007matman's Avatar
Originally Posted by A32Deuce View Post
Gorilla tape.
Ditto.
Black is available at Wally-World.
007matman is offline   Reply With Quote
Old 08-07-2019, 07:14 AM   #4
Thanks guys. I was thinking that same thing (gorilla tape) but came here first to make sure no one said "noooo don't do that!" haha
Old 08-07-2019, 07:24 AM   #5
SnJGuin's Avatar
I used a tape for my Puma XLE underbelly and would recommend it. Here is the Amazon link to the tape and a picture of what I patched.
Mobile Home RV Flex Mend Belly... https://www.amazon.com/dp/B017UNKBBC...p_mob_ap_shareClick image for larger version
Thanks,
Scott
TT: 2019 Palomino Puma XLE Toy Hauler 25TFC
TV: 2001 Chevrolet Silverado 2500HD 4x4 CC
SnJGuin is offline   Reply With Quote
Old 08-07-2019, 07:33 AM   #6
007matman's Avatar
I have a roll of Black and a roll of White as well as a few assorted pieces of Eternabond in my camper at all times.
White is great for small awning tears or to quick patch leaking seam/seal or window. It can be removed later and cleaned up (unlike Eternabond).
Old 08-07-2019, 07:56 AM   #7
Just a point of reference-eternabond is removable. Donít ask how I know....I found acetone works well.
There is also a product called scrimshield (Amazon) that is a super adhesive vapor barrier. It is designed for sealing out water under the trailer
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 08-07-2019, 08:23 AM   #8
007matman's Avatar
Interesting. I guess I'd always heard it wasn't removable.
I know that Acetone works on my Fiberglass but plastic is another story.
Old 08-07-2019, 08:47 PM   #9
Eternabond solvent
Eternabond removes and cleans easily. I just finished removing 8' x 4" of it.
You need a heat gun, a dull scraper/putty knife. a cardboard box, some rags, mineral spirits, and alcohol.
Heat the a few inches of tape and gently scrape it off. (If you like, you can grasp the vinyl backing and peel it off.) Scrape the adhesive off the scraper onto the rim of the cardboard box.
When you have all the vinyl off and the bulk of the adhesive, take a second pass with the heat gun and scraper.
Scrub the remaining adhesive off using rags and mineral spirits. The EPDM roof will be clean, but it will feel a little "oily." Do a quick wipe with Isopropyl alcohol (cheap rubbing alcohol from the drugstore). Thanks to RSData who recommended the alcohol wipe after cleaning with spririts.
Larry
Larry-NC is offline   Reply With Quote
Old 08-07-2019, 08:49 PM   #10
No acetone
I would not use acetone. It quickly eats paint and is not approved for EPDM roofs.
Use mineral spirits which is approved for EPDM roof.
(This weekend I had a gallon of acetone but no spirits. I drove 20 miles to get some, rather than use acetone on an EPDM roof.)
Larry
cover, underbelly
