Old 10-18-2018, 08:11 PM   #1
Moisture
I am getting moisture around the seatbelt bolt under the dinette seat. Does the bolt go all the way through the floor? Freelander 29 qb 2013
Panhandler is offline   Reply With Quote
Old 10-19-2018, 09:01 AM   #2
Thought it would repost since I didnít get any responses can i seal it from underneath
Old 10-19-2018, 09:05 AM   #3
AquaMan's Avatar
The seatbelt bolt more than likely goes all the way through. When you say "moisture", is there standing water or just damp? It could be that the bolt is sweating from the change in temps (although I'm not sure where you are locaed).
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 10-19-2018, 09:11 AM   #4
There is corrosion around the bolts it goes up along the cloth part of the seatbelt. Not sure if it is mound but it looks like some type of corrosion no standing water
Old 10-19-2018, 09:14 AM   #5
I looked under unit and do not see any bolts or nuts in that area
Old 10-19-2018, 09:17 AM   #6
AquaMan's Avatar
My guess is that the metal of the bolt and belt attachment is just sweating from changes in temp. You could cover the bottom side of the bolt with spray foam to insulate, may or may not help.
Old 10-19-2018, 04:56 PM   #7
After further investigation the dinette seat I am looking at has discoloration all along the bottom of the wooden back. The back of the dinette is behind the passenger seat. I am wondering if there May be water intrusion where the cab of the truck meets the body of the camper(this is a class C Motorhome.
Do you know how the two are attached?
Old 10-19-2018, 04:58 PM   #8
I have called Coachman with no call back since 10am
