Old 02-04-2017, 12:20 PM   #1
ed9
Molding Separation Getting Worse
What can be done?
ID:	129144Click image for larger version
ed9 is offline   Reply With Quote
Old 02-05-2017, 12:56 PM   #2
ed9
Separation at exterior corners
Hi
Can anyone give some tips to permanently fix exterior seams at corners? 2013 Rockwood SIG Lite 5th where.
Old 02-05-2017, 01:02 PM   #3
ed9
Any suggestions for a permanent fix is appreciated.
Old 02-05-2017, 01:02 PM   #4
crunchman12001's Avatar
Hi,
Can you post some pictures of the damaged areas so we can tell you how to fix it?
2015 F-250 FX4
Old 02-05-2017, 01:05 PM   #5
ok, you have two threads going on same issue. You own a 2013 Rockwood SIG Lite 5th wheel.
Did you buy it like this or did you hit something?
2015 F-250 FX4
Old 02-05-2017, 01:20 PM   #6
wmtire's Avatar
Multiple threads merged into this one as per the site guidelines:
http://www.forestriverforums.com/for...ork&page=rules
Do not post the same discussion topic more than once or in several areas of the forum.
2011 Flagstaff 831 RLBSS
Old 02-05-2017, 01:47 PM   #7
Herk7769's Avatar
Looks like you clipped something backing in.
I would just add another screw to hold the bent piece down and re-caulk with Proflex sealant.
Here is the link to black:
0 28103 Proflex RV Flexible Sealant Black 10 oz.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 02-05-2017, 01:51 PM   #8
rracer5's Avatar
Unfortunately, it looks like there has been water intrusion do to failure of the caulking. The molding is screwed into the edge of the flooring/substrate and due to moisture, the edge of the floor/substrate can no longer hold the screws. To do a permanent repair, you may have to tear apart the interior in both corners, pull up carpet/lenolium, check for mold and treat or cut out the damaged area and replace. Then resecure the molding and recaulk. You can buy new molding and insert from a good camping supply outlet.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 02-05-2017, 01:54 PM   #9
rracer5's Avatar
Herk, I think the pics are of the 2 rear corners so, I think it "looks" like more of a sealant/water intrusion problem.......but, don't quote me on that.
Old 02-05-2017, 02:25 PM   #10
Herk7769's Avatar
Ah, I see that now. He has a severe problem in that case.
I would make an appointment at the factory.
Old 02-05-2017, 02:40 PM   #11
rracer5's Avatar
X2 ESPECIALLY if it's under warranty.
Old 02-20-2017, 03:05 PM   #12
ed9
Thanks. Not under warranty.
exterior, mold
