on my ,04 cedar creek the roof material has lifted at the corner at back seam where it meets end cap does not look like it is leaking but it is bubbled up can I just cover with eternabond tape as I plan on taping endcap seam anyway.or do I have to somehow reseal under EDPM then tape?
if the sealant is on tight I would go over it AFTER CLEANING THE CAULK... less possible damage to the roof... if there are gaps and you can peel it up, then yes I might try to peel off what I can...
here is a link to a thread I did recently while doing roof work on my camper using Eternabond...
