Old 03-13-2016, 11:17 AM   #21
Originally Posted by phillyg View Post
It happens and I don't think it's a bad bubble. If the dealer isn't willing to fix it, then dave's procedure is what I would do. I wouldn't make a very big slit, and after the rubber has dried, I would put a piece of Eternabond tape over the slit.
I would just poke a small hole in the center of the bubble and work the air out and seal it with an Eternabond patch.
Old 03-14-2016, 06:34 AM   #22
Wolverine 1945's Avatar
You guys would really do that to a 3 month old unit ???
I guess if that is what you want to do,,, I think you can buy a hypo needle that would inject glue ???
Wolverine 1945 is offline   Reply With Quote
Old 03-14-2016, 02:02 PM   #23
I would certainly expect the dealer and FR repair the bubble. But it doesn't require replacement of the entire roof as some have said. If the dealer/FR doesn't step up, then yes, I would repair it as previously stated. The hypo is a good idea.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 03-14-2016, 02:43 PM   #24
hammer55's Avatar
they could repair one for me if, if, if, they would guaranty that in "that spot would never ever leak" other wise they would have to replace the whole thing for me to accept it, just sayin, they seem to get away with a lot, the roof should not be one of them
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 03-14-2016, 02:46 PM   #25
AquaMan's Avatar
Whatever the OP does, I surely hope he doesn't "poke a hole" or "cut a slit" in a his roof. That is simple the worse kind of advice. Don't put a hole in something that shouldn't have one. The bubble does not hurt anything, and will most likely go away. It's not broke, don't "fix" it.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 03-14-2016, 03:04 PM   #26
, yeah really. Can't believe someone would even THINK about cutting into their roof membrane. That would definitely void the warranty, probably affect insurance coverage also.
Brewhedd is offline   Reply With Quote
Old 03-14-2016, 04:02 PM   #27
If you bought a new house and discovered a leak, let's say three months later, would you expect the builder to replace the entire roof?
Old 03-14-2016, 05:07 PM   #28
Hi
I have been reading your last few posts on bubbles.
I assume this is a delamination issue.
I just sold my Chalet trailer just for that reason and I was wondering if this is an issue with the FR Aframe trailers too.
I am considering buying one.
Aframe-camper is offline   Reply With Quote
Old 03-14-2016, 06:24 PM   #29
World Wide Wanderer
wahoonc's Avatar
Originally Posted by Aframe-camper View Post
Hi
Different types of roof. The OP has a "rubber" roof that is glued to the substrate. They get small bubbles in them occasionally. Not the same thing as a fiberglass delamination.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is online now   Reply With Quote
Old 03-14-2016, 11:28 PM   #30
I actually would poke a needle size hole (use needle used to vaccinate horses) to draw out air and inject an appropriate glue into the area that has come loose. The hole would be about the size of a pen tip and afterwords, use some eternabond tape to seal it up and also seal that Dicor job on the vent..it is begging for eternabond.
Remarks to return it to factory or dealership are a little extreme. If you are not comfortable on putting a tiny hole in it to fix it, you can remove dicor next to the vent, remove vent, and inject glue into that area from the side and press out air towards vent so it seats flat.
Skyliner is offline   Reply With Quote
roo, roof
