Old 09-22-2016, 01:36 PM   #11
Originally Posted by Iwannacamp View Post
3M makes a product called marine 5200 sealant(I think) i have used it on several jobs and it works great. Only drawback I have seen is that it dries slow.
But once dry it's permenant
Good stuff
pdqparalegal1 is offline   Reply With Quote
Old 09-22-2016, 04:49 PM   #12
LandJ's Avatar
When we installed my washer/dryer vent, we put buytl tape behind it. This is the same stuff you'll find around doors and windows.
https://www.amazon.com/Dicor-BT-1834.../dp/B001FCB4JS
Thanks! I ordered from your link....
_________________
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2015 - 36 nights
2016 - 47 nights
LandJ is offline   Reply With Quote
Old 09-22-2016, 09:39 PM   #13
they also have a quick drying version, Its 5200 fast dry. Its waterproof and dries within 24 hours.
fastwilly is offline   Reply With Quote
Old 09-23-2016, 01:05 AM   #14
dmchapman's Avatar
Originally Posted by stevejahr View Post
I just used silicone when I put in the rails on my slide covers. I also made sure that each screw was set in silicone.
Do not go crazy with the screw length... the walls are only 1" thick so it does not take much to run all the way through.
So folks remove the gas cylinders on the doors? Had not been too bothered by those yet. But I will keep this in mind for when the cylinder mounts get too bent
We took the strut off for several reasons. We like a door that fully opens, especially at home where space is tight. The strut didn't hold the door firmly in breezy conditions. With the T catch it doesn't flap around.
dmchapman is offline   Reply With Quote
