Old 09-22-2016, 10:53 AM   #1
LandJ's Avatar
Need help putting screws into outside wall
I need some help from the experts, Iíve been searching on and off for a week or so.
I bought some door holdbacks for my Rockwood 2604, but Iím concerned about water intrusion once I drill holes and put screws into trailer. The holdback has an irregular shape on the inside and is not completely closed off to the weather. I was at a local dealer, and noticed that the manufacturer (not FR) had used some sort of sealant tape behind the same holdback that I purchased. I donít know what it is, and I even called 3M to see if they could helpÖ. they claimed to not have a product for my application.
Can anyone give me detailed instruction on how to seal up screws to ensure the threat of delam is kept to a minimum?
Here is a link to the holdbacks that I purchased:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks in advance!
_________________
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2015 - 36 nights
2016 - 47 nights
LandJ is offline   Reply With Quote
Old 09-22-2016, 11:12 AM   #2
Fulltime family RVer
When we installed my washer/dryer vent, we put buytl tape behind it. This is the same stuff you'll find around doors and windows.
https://www.amazon.com/Dicor-BT-1834.../dp/B001FCB4JS
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 09-22-2016, 11:54 AM   #3
jeff
jeff64's Avatar
Use butyl tape like ependydad says. Remember you are going through 1 layer of fiberglass. Don't go hogwild with the screwdriver! The butyl tape will compress and stick the fixtures to the TT. Two finger tight. Go back and two finger tight again after a couple hours. By the 3rd time, leave it alone! I see these are the old "T" style latches and you probably got rid of the air cylinder as I did. My challenge was the tilt out window that interfered with the back door where I used the 6" variety.
Door side notes:
You can remove the putty under the opening, but leave enough to seal the flat surfaces. I left a small gap between the bottom screws on the door side fixture. When I installed that piece, I inserted a tie wrap in the gap, did my final tightening on the screws and pulled the tie wrap out. That way the water drains out of that door fixture when it rains. Otherwise, it holds water.
Coach side note:
Same deal, forget the space for the water drain, BUT remove an area behind the axle and t-bar. When you do the tightening sequence the caulk will migrate in that area and it will not be totally free and will appear gummy
Did you remember to buy the bumpers? https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Do not make screw holes in the tape, let the screw do it during insertion. If you do this right with the bumpers, they will locate in one of the coach fixture mounting holes at the upper left and when you swing open the door will contact the door fixture at the upper right screw hole. Tape in place, use square and measure. It probably took a couple hours by the time I got done with it all. Take your time
ID:	120957   Click image for larger version
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-22-2016, 11:59 AM   #4
gwj123's Avatar
I added a new door holder and just used clear silicon to seal on the door and TT. I added the silicon to the holder, then screwed them in, then wiped off excess.
2016 RAM Laramie 2500 CC 4x4 Cummins Turbo Diesel
2017 Forest River Wildwood X-Lite 254RLXL
gwj123 is offline   Reply With Quote
Old 09-22-2016, 12:00 PM   #5
Iwannacamp's Avatar
3M makes a product called marine 5200 sealant(I think) i have used it on several jobs and it works great. Only drawback I have seen is that it dries slow.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Iwannacamp is online now   Reply With Quote
Old 09-22-2016, 12:50 PM   #6
dmchapman's Avatar
Door side notes:
Coach side note:
When I did the same mod I also purchased a 3" bumper/stopper and positioned it so the door cannot contact the window even when fully extended.
dmchapman is offline   Reply With Quote
Old 09-22-2016, 12:53 PM   #7
camaraderie's Avatar
5200 is a permanent marine adhesive. It should never be used where the item may have to be removed someday. It is primarily used on boats on things like hull/deck joints and is wonderful for those kind of purposes. They also make a 4200 adhesive which is a bit easier to remove...but still a pain! The best choice for the job at hand is simple butyl since adhesion is not a requirement and the butyl will keep the water out and stay flexible in a wide range of temperatures.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 09-22-2016, 01:00 PM   #8
Heh, back when I did some kayak building- there was a saying:
- if you hate your future self, use 4200
- if you really your future self, use 5200
Or something like that. I have a tube of it that I literally am afraid to use!
Old 09-22-2016, 01:13 PM   #9
Learning a lot as I go...
I just used silicone when I put in the rails on my slide covers. I also made sure that each screw was set in silicone.
Do not go crazy with the screw length... the walls are only 1" thick so it does not take much to run all the way through.
So folks remove the gas cylinders on the doors? Had not been too bothered by those yet. But I will keep this in mind for when the cylinder mounts get too bent
2015 Rockwood 2604WS (sold as 2016)
2014 Ford F-150 Ecoboost
stevejahr is offline   Reply With Quote
Old 09-22-2016, 01:18 PM   #10
Iwannacamp's Avatar
LOL That's funny. I just know it works. Water IS the ENEMY
2017 Puma 297RLSS
