Old 05-25-2011, 11:14 PM   #1
need help with air roof vents
I am a newbie and need advice for purchasing a new roof air vent. I have a damaged one but don't know what to buy. I have seen a Ventline model that is 14 in x 14 inch- just looks like a simple standard vent and wondered if it would work for me. I have a 1980 Fleetwood Prowler. Thanks for any advice!
1980prowler is offline   Reply With Quote
Old 05-26-2011, 07:04 AM   #2
MtnGuy's Avatar
If just the cover is bad, then you may be able to replace that without pulling the whole unit out. Remove the cover and take it into your local RV store and see if they can get a replacement.
BTW, welcome to the forum !!
Old 05-26-2011, 08:49 AM   #3
roof vent replacements
I just replaced 2 on my Cardinal 5th wheel . You have to unscrew the crank handle then remove the crank meck. slide out the rizer arm and then go up just slide off . they have several different kinds . Take your old one and make sure the hinge is same height. Really simple to do tho.
Rick
tebitt is offline   Reply With Quote
