Old 08-11-2015, 03:08 PM   #1
Not too spiffy...
As a result of our warm (hot) summers, what I figure is melting caulking around the windows has formed hard "drips". Short of a razor blade and the good opportunity to permanently damage the surface, how do I make these go away?
OTRagain is offline   Reply With Quote
Old 08-22-2015, 10:17 PM   #2
I just used a utility knife and some caution. Then I used gas to clean up
aullie70 is offline   Reply With Quote
Old 08-22-2015, 10:53 PM   #3
TimVWulp's Avatar
Mineral sprites or kerosene on a rag should remove the caulking. Don't use a tool to remove the caulking it will damage the unit.
Hope this helps Tim
TimVWulp is offline   Reply With Quote
Old 08-22-2015, 10:59 PM   #4
Iwannacamp's Avatar
Mine did this under the door. I used some Awesome cleaner... Came right off
2017 Puma 297RLSS
Old 08-23-2015, 12:10 AM   #5
I agree that the knife can do damage so if cleaners work it is best to go that route.
Old 08-23-2015, 12:28 AM   #6
I agree on the cleaners. I keep hearing this Awesome product. I'll try it first. Thanks.
Old 08-25-2015, 08:56 AM   #7
Iwannacamp, I got the all-purpose Awesome. It's very concentrated. What ratio did you use and exactly how did you apply it?
Old 08-26-2015, 10:13 PM   #8
Iwannacamp's Avatar
Hmmm. This is Arkansas... The stronger the better. I just sprayed out of the bottle. WD-40 would prolly work too, but my trailer is metal I am not sure about fiberglass.
2017 Puma 297RLSS
Old 08-26-2015, 10:15 PM   #9
Iwannacamp's Avatar
Ohhh and wiped with a cotton rag
2017 Puma 297RLSS
Old 08-26-2015, 10:22 PM   #10
Taranwanderer's Avatar
If it's semi-pliable caulking, I would think that a plastic scraper or putty knife type of tool might help without damaging the underlying surface.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-26-2015, 11:29 PM   #11
TimVWulp's Avatar
Use caution with some cleaners. I have learned the hard way with past TT when i damaged the paint on a metal sided units with the cleaner Don't let the cleaner dry of stand on the unit to long use caution.
Hope tis helps Tim
