Old 04-08-2014, 01:50 AM   #1
Out side storage
We live in phoenix it will be the first summer we will have our 2014 travel trailer in the very high heat and sun. Is it a really bad idea to leave it in phoenix? Should we park it back up north for the summer to avoid the heat? Any tips or advice? Still very new to this.
Katie
Kcompt01 is offline   Reply With Quote
Old 04-08-2014, 04:04 AM   #2
BigTJohn's Avatar
Some people store trailers in freezing weather - no problems when done right. Some people store trailers in the desert - no problem if done right. That said think about what might go wrong in high heat. Plastic can soften - remove any vinyl sheeting, bags, film-like stuff, etc. fully inflate tires, try to park where there might be some shade (right...) drain all the water - water heater, storage tank, all holding tanks, etc. Leave NOTHING food wise on board as desert critters are desperate for: 1. water, 2. food, 3. shade. Be careful when coming back to open up the rig as critters may be hiding where you least expect. Now think about venting the rig. If rain is not an issue, a very small gap in window or upper vent may help tremendously. It can easily get over 150*f inside. Cover the windows from the inside with foil insulation to prevent any sunlight from entering. That ought to get you started. Also check with others whom leave their rigs in place and scurry back to the N.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 04-09-2014, 04:09 PM   #3
I am in SE Texas were it is hot and humid. I don't leave my fiver, 2012 V-Cross 275, out in the sun during the summer without the AC on, set on 80 F. Good Luck
whj77372 is offline   Reply With Quote
storage
