Old 08-19-2017, 12:40 AM   #1
painting top of slide
Our 5th wheel is an o6 and looks like new inside so we try to take good care of it, My question is can we paint the top of the slide with a roofing paint to better protect it?
otisco1 is offline   Reply With Quote
Old 08-20-2017, 12:48 PM   #2
King of the Road
Don't think it would hurt anything, make sure you use a good primer that will stick so the paint won't flake off easily. Check it at least annually in case you need to reapply.
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
Old 08-20-2017, 08:20 PM   #3
Thurman's Avatar
It would depend on what material is on the top of the slide. Mine, for instance, is the same rubber roofing that is on the main roof. I would not paint a rubber roof. Proper cleaning and coating of a rubber roof with the appropriate product should do.
Thurman is offline   Reply With Quote
Old 08-20-2017, 08:42 PM   #4
heavynlori's Avatar
We used a product called Liquid Roof on a previous slide roof that had a small tear
This was before we heard of Eternabond Tape
Anyhow, it was a fabulous product and easy to apply - they can be found online if you search for that product - they also have a product called Liquid Rubber but the liquid roof was recommended on their website for what we did
We did the entire slide roof and around all the "things" on the roof also with one gallon - the slide was the couch/dinette huge slide
heavynlori is offline   Reply With Quote
Old 08-22-2017, 09:58 AM   #5
Wolverine 1945's Avatar
If it is a rubber roof,,, Thurman is Right On !!!
Wolverine 1945 is offline   Reply With Quote
slide
