Old 07-01-2019, 04:42 PM   #1
Patch a Hole
I think that during a hail storm we had a while back one of my skylights had a hole about as big as a nickel punched in it. One of the other skylights has a crack where it was hit also. I just noticed it last week. I don't think I have to do anything to the one that is cracked but I have to do something with the one that has the hole. It is clear plastic. Not very thick. Is there some kind of patching kit I can use to seal it up?
bill18163 is offline   Reply With Quote
Old 07-01-2019, 04:48 PM   #2
Lame *****
Eternabond. Dicor lap seals on the veritcal seams, Trempro 645 on horizontal. My work is for PM but could be a solution for you.
Or replace it.
Maggot
Maggot is offline   Reply With Quote
Old 07-01-2019, 04:51 PM   #3
Eternabond tape is likely the quickest easiest fix short of replacing.
If you have a crack in one, you WILL need to fix that too.
Days Camped: '16=46 '17=30 '18=51 '19=27
