Old 11-18-2017, 07:23 PM   #1
Pine tree help
Getting my TT ready to put up for the winter. Was washing the outside and noticed some pine rosin was on the side and also on roof. Probably came from our last trip where our site was under some tall white pines. Any suggestions what will remove it and not damage the fiberglass or roof? Thanks in advance.
Stikman is offline   Reply With Quote
Old 11-18-2017, 08:02 PM   #2
I've had good luck with LPS1 for removing sticky stuff. I think WD40 will work too.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 11-19-2017, 08:15 PM   #3
stikman, on a trip last year I got pine sap on the one awning, roof and windshield. I wasn't worried about anything but the slide awning until I got home. Charcoal lighter fluid worked wonders on everything and I didn't see any problems using it . What I did was used water to wash the areas after the lighter fluid. If I had put my slide in before cleaning, I do believe I would of had problems because of how sticky it was. Good Luck.
shortkid is offline   Reply With Quote
Old 11-19-2017, 08:30 PM   #4
Rubbing alcohol works great.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
