Old 04-05-2019, 04:21 PM   #1
Pole Cleaning Brush Recommendations
I decided a pole mounted brush would help to facilitate washing my trailer. After a few search attempts, I am not finding much help from prior threads. I am seeing brushes from the $20 range up to $60.
Curious what others have found to be a good choice.
2019 Freedom UltraLight 192RBS
2018 Sierra 2500HD Duramax
Anderson WD Hitch
TST 507 TPMS
nutdriver is online now   Reply With Quote
Old 04-05-2019, 04:55 PM   #2
Costco has one on sale right now, less than $20.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 04-05-2019, 04:59 PM   #3
Gwiggels's Avatar
I used one from Costco last season. Not sure if it is the same one you are talking about or not.....but, I did not like it. The brush head was very heavy and made it hard to use fully extended. It had a container that held soap and could hook up to a garden hose to soap and rinse the RV. The soap and the water connections both leaked. The brush head also was a little to stiff in my opinion.
Just my 2 cents
Gwiggels is offline   Reply With Quote
Old 04-05-2019, 05:04 PM   #4
heavynlori's Avatar
We bought an extendable handle (twist to loosen/tighten after extended) from West Marine
Lightweight aluminum handle and a pop on/off soft brush head - it reaches the high points of our 5er easily
heavynlori is offline   Reply With Quote
Old 04-05-2019, 05:04 PM   #5
Gwiggels's Avatar
Surprisingly enough, this cheap one has been most successful for meClick image for larger version
Old 04-05-2019, 05:11 PM   #6
Just my 2 cents
I was just at Costco and I think it's different than the one you used last season.
IMO, those pole brushes should not have a hose hooked up to them, you get more water on you than the coach. As you mentioned, once filled with water and with the hose connected, the pole brush gets heavy and leaky
Use the bucket-dip method, dip the unattached pole brush in a bucket with your favorite car wash liquid and water and wash the sides. Rinse with a hose afterwards.
Old 04-05-2019, 05:13 PM   #7
Gwiggels's Avatar
I couldn't agree more.
Old 04-05-2019, 06:57 PM   #8
I really appreciate the input and thoughts.
I was already feeling a bit hesitant to go with the poles that have the water flowing through the handle for many of the reasons given. My inclination is to keep it simple.
I did look at the AutoSpa but it is now only available from 3rd party sellers on Amazo* and the negative reviews were a bit concerning.
The idea expressed by heavynlori probably is what I am leaning toward. Extension pole and brush that I can dip into a wash bucket. I do wish I had a West Marine convenient to me but I would probably end up needing to pay for shipping which will push the cost up. I think I will start narrowing my search along this line.
Anderson WD Hitch
TST 507 TPMS
Old 04-05-2019, 07:04 PM   #9
waybeck2018
waybeck2018's Avatar
I saw one in Harbor Freight two days ago. Heading back tomorrow with my discount coupon to get one. Less than $20.00 then use 20% off coupon.
2012 F-250, 6.7 Super Duty Powerstroke; 2019 291 BR Primetime Tracer,
Days camped in 2018-61
Looking Forward to Completing This Map Soon !
waybeck2018 is offline   Reply With Quote
Old 04-05-2019, 07:07 PM   #10
Go to any large truck stop, they will have the telescoping pole and brush, the most heavy duty ones around, will last forever!
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
jackhartjr is offline   Reply With Quote
cleaning
