Old 10-02-2013, 05:48 PM   #1
BarryOFlynn
Power stablizer jacks
Hi
Both jacks quite working at the same time
I checked the fuse panel in the power centre but there isn't any fuse named for the jacks
I called the dealer who said check the 30 amp fuse close to the tongue. I found two 30"s and both are ok
Any ideas
BarryOFlynn is offline   Reply With Quote
Old 10-02-2013, 05:59 PM   #2
You didt say what type of R/V you have,but a WAG is trailer and Look agin in the Power center for a Blown Fuse! Youroo!!
Old 10-02-2013, 06:14 PM   #3
BarryOFlynn
Hi
Trailer is 2013 Rockwood Ultralite 2604
The fuses have a lite that shows if fuse is blown. There are no lites on
Old 10-02-2013, 06:49 PM   #4
davidjb's Avatar
follow the wiring you might have a relay that needs to be reset
davidjb is offline   Reply With Quote
Old 10-02-2013, 07:15 PM   #5
BarryOFlynn
Thanks for the steer There was a 20 amp fuse tucked down in the bottom of the power centre
jacks, power
