Old 11-28-2015, 04:36 PM   #1
Protecting rain spouts when covering???
We had rain spouts added to the gutters on our Class C purchased this past Spring. Just got an ADCO cover and don't want the cover flapping to break them off. Any suggestions on how to protect them?
suscamper is offline   Reply With Quote
Old 11-28-2015, 04:42 PM   #2
Ford Idaho's Avatar
Odds are the spouts will trash the cover first.
Pool noodle or tennis balls with a X cut in them are what most use.
Old 11-28-2015, 04:53 PM   #3
tomjsas's Avatar
We have used the tennis balls based on a post here and in four years neither the cover or downspouts have suffered any damage. Now wish the same could be said for the cover where it met the stairs. Have learned to use an old ladder cover from our previous camper cover to keep it from damaging the new cover any further.
Tom
2004 Fleetwood Providence 38U
currently not towing a toad
tomjsas is offline   Reply With Quote
Old 11-28-2015, 05:20 PM   #4
Flybob's Avatar
X2 Pool Noodles
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-28-2015, 05:22 PM   #5
RSchleder's Avatar
We used the "miniature" tennis balls which come in a 6-8 ball pack. These balls are the type a lot of folks purchase for dog toys. They worked prefect after i cut an X on the end and carefully wedged them onto the rain gutters. Just take some care when putting the cover on so you don't inadvertently dislodge the balls.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 11-29-2015, 01:08 PM   #6
Boso's Avatar
Rv cover
My cover came with little bags that go over the gutters much easier to keep on put the tennis balls over the other sharp objects the covers are about 1.5" wide by 5" deep with string to tighten
Boso is offline   Reply With Quote
Old 11-29-2015, 01:34 PM   #7
harleyguy's Avatar
Have used tennis balls with X's cut in them for the last two years and haven't had any issues
harleyguy is offline   Reply With Quote
Old 11-29-2015, 01:37 PM   #8
I have seen some people stick a roll of toilet paper over the spouts.
CLewis is offline   Reply With Quote
Old 11-29-2015, 01:52 PM   #9
DustyRoads's Avatar
When covering???
I zip tie foam used to cover pipes to the ends of down spouts. This is more to prevent the down spouts from ripping the cover. Which happened to my son-in-laws cover on their trailer. I like the idea of using pool noodles but I have had difficulty finding when I am closing up the trailer. I use the red pool noodles for protecting heads from low windows and slide out corners.
Good luck!!
DustyRoads is offline   Reply With Quote
Old 11-29-2015, 05:01 PM   #10
I purchased some round pipe insulation the tube kind. I cut small pieces and folded them in half. I used pulled ties to secure them to the rain spouts to protect my cover. I've done it for three years now and have had no problems.
Bears1985 is offline   Reply With Quote
Old 11-29-2015, 05:24 PM   #11
Very important!
Mr Havercamp is offline   Reply With Quote
Old 11-29-2015, 05:59 PM   #12
Tennis balls are probably the best solution. Before I learned of using them, I used blue painters' tape wound around the gutters, extended beyond the ends. Stayed secure all winter yet did not leave any glue when removed in the Spring.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
CNYCamper is offline   Reply With Quote
Old 11-29-2015, 08:08 PM   #13
Another adventure awaits!
HESN22's Avatar
My husband cut up a pool noodle and tightened them on with zap straps ... Worked great ...
HESN22 is offline   Reply With Quote
Old 11-30-2015, 04:54 PM   #14
Simple the paperwork that comes with the cover should have told you about this issue (very common issue) just take a roll of toilet paper and tape them in place over the ends of the rain gutters and you are good to go with your cover.Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 12-01-2015, 01:35 AM   #15
Our cover came with the little pillowcase type covers for the downspouts. The case stayed on and the downspout still poked a hole in the new cover. Now we are using tennis balls.
2020 Rockwood 2608BS
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
2021 Ford F-250 Super Duty
OscarsMom2 is offline   Reply With Quote
cover
