Old 05-05-2013, 12:41 AM   #1
Fire Instructor's Avatar
Question on Resealing Roof Seams and Penetrations
I've seen others post that they reseal joints and penetrations in the roof every year or so with Dicor. I've never done this, but I can see some areas on my roof that would be likely locations for some TLC.
My question is, do I scrape as much of the old Dicor away before applying new? Or should I just coat over the top of existing Dicor?
Thank you, in advance, for any assistance!
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 05-05-2013, 05:55 AM   #2
Herk7769's Avatar
I used a cloth (I use WHITE Box-o-Rags) wetted (damp) with Acetone to wipe the surface of the old Dicor. This will remove the white chalk buildup and make the surface "sticky" to improve adherence of the new Dicor and allow it to flow into the cracks.
You can also use Eternabond Primer (basically spray Acetone), but it won't remove the chalk just make it sticky and become part of the repair.
I put Eternabond tape seal on my seams 2 years ago and just do my annual inspection. I still carry a tube Dicor, a small roll of EB tape, and a can of Primer for emergency repairs (tree strikes etc).
HAM CALLSIGN - KC3FFW
Old 05-05-2013, 07:14 AM   #3
realebill's Avatar
One area to also check would be all the areas where there are screws going through the side wall of your trailer,especially along the top.
We had a leak along one side of our rockwood 8315SS. 2 years ago,upon opening the trailer for the season,i noticed water stains at several points inside the trailer. at the kitchen window,at the top of the entry door and inside the rear storage area plus what looked like the start of some delamination on the outside wall of the trailer. i assumed that since we had a heavy snow that winter,that may have accounted for the leaks. but,just to be on the safe side i decided to "eternabond ALL the seams on the roof.got the tape,applied it and thought all my leaks were stopped. several weeks later,opening the trailer we discovered a wet spot on the bed and discovered that water had leaked from the a/c vent above the bed.we still had the leak. next,check all the possible water entry points.i checked where any screws were going through the side wall. after removing the rubber strip on the top rail,(the rail that holds the roof fabric where it overlaps the side)i saw that most of the screws were rusty(on a 2008 trailer).Hopefully,i had discovered the water point of entry. I decided to replace all the screws in this strip with SS screws,(about 70 on each side) about 1/3 of the screws were totally rusty and some were even wet !i replaced all the screws,made sure they were snugged up tight,and even dipped the threads in dicor caulk before i screwed them in. Now after 2 years,absolutely no leaks at all. one thing i will do is to recheck every year the roof tape and retighten all the screws that i replaced. this picture is from my neighbors trailer who had the same problem that i had.not only are the screws rusty,but were also loose,allowing water to seep into the side.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 05-12-2013, 02:58 PM   #4
I thought you couldn't use petroleum distillates(acetone) on rubber roof. It degrades it.
campbuzz98 is offline   Reply With Quote
Old 05-12-2013, 03:07 PM   #5
TURBS's Avatar
You can if you just wipe it with a damp cloth.
not soaking dripping wet.
And never pour on and wipe around!
