Old 10-23-2014, 02:53 PM   #1
Re-caulking roof, remove old first??
I have an 07 Surveyor. All of the vents in the roof have a very thick, wide band of caulking (there when I bought it). This had split along vents. I'm going to recaulk, but was curious, do I try to peel off that black stuff first, or just caulk on top of it? Thanks!
erin175 is offline   Reply With Quote
Old 10-23-2014, 02:58 PM   #2
MtnGuy's Avatar
I just caulk on top of the old, making sure I fill all of the little cracks.
Old 10-23-2014, 03:00 PM   #3
Sorry, tried to put photo in the original post. But this is the issue(s) I'm trying to correct!
Old 10-23-2014, 03:16 PM   #4
PhoneDude 8289's Avatar
Area to be caulked should be cleaned real good before caulking, caulk don't stick or seal well if the area isn't clean. I use simple green first then I go over it with alcohol / water 50 /50 and a final rinse of plane water. Let it dry real good then caulk away.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 10-23-2014, 03:16 PM   #5
Clean with alcohol (denatured) really well and cover with the self leveling roof caulking.
whitmw is offline   Reply With Quote
Old 10-23-2014, 03:42 PM   #6
Take The Road Less Travld
MuddauberE's Avatar
when I first saw the picture, the work clean came to my mind first as well .
Use self leveling calk right over the top of the old. Not sure why, but no one says to clean off the old. I assume it seaps into the cracks of the old and creates a new seal. Maybe it's just a waste of time or maybe it's just impossible to remove the old. Just relaying what I've heard. As a side note, Use LAP sealant to reseal around doors and windows.
Some people will apply eternabond tape over new seals to help them last longer. Guess you can never be too careful.
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2017 Ford F-150 EB
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 10-23-2014, 03:52 PM   #7
I've read such contradicting reports on "cleaning" the rubber roofing (I understand you're referring to the caulk specifically) but man, it's so nasty to look up there!! Might have to give it a light scrub-down in the spring!
roo, roof
