Old 08-25-2018, 05:17 AM   #1
Remove under insulation and fabric???
The underbelly fabric and insulation at the front of my Forest River 19rr is wet and sagging. Appears water entered through the joint at the front of trailer during a drive in a monsoon type rain storm.
Has anyone removed this fabric and insulation and replaced with rigid foam?
RB19RR is offline   Reply With Quote
Old 08-25-2018, 05:48 AM   #2
Had the same happen on my 2016 Shasta 185 FQ. Mine was at where front cap meets aluminum tread plate. The trim that cover the joint was just another example of ďfine workmanship ď resulting in lack of proper sealing at factory during build. I removed strip, cleaned, reapplied byutl caulk and reinstalled trim. Then I removed the coroplast on underside of RV below effected area, removed insulation, let dry for few days, sprayed with Wet and Forget mold and mildew killer. Then sprayed rubberized undercoating on all areas effected and reinstalled coroplast liner. Have had no more problem since. This happened within few weeks of purchase of when it was NEW. May the fleas of a thousand camels infest the armpits of these so called factory trained employees that donít care about providing a quality properly built product.
Decon Blue is offline   Reply With Quote
insulation
