Old 03-18-2012, 03:22 PM   #21
The best thing you can do about black streaks is to not get them in the first place. If your RV does not have rain-gutter extensions (the one's that stick out about 4" or so) install one on every short drip spout on your RV and this will substantially reduce or even eliminate your "black streak problem" by moving the run-off from your roof outwards beyond the sidewalls of your RV.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 03-18-2012, 07:22 PM   #22
Mountainmanbob's Avatar
our's has those
came with it
but
for those who do not
saw them for a low price at WallMart
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 03-18-2012, 07:46 PM   #23
PapaSmurf's Avatar
I wash mine with Tide with bleach laundry detergent. The black streaks simply wash away and the camper shines like a new penny.
2011 Ram Truck 2500, Crew Cab, 6.7L CTD, 4X4, 3.73 Rear
PapaSmurf is offline   Reply With Quote
Old 03-18-2012, 08:19 PM   #24
I just used Meguiars Cleaning Wax yesterday and it did take off the black streaks on our aluminium siding - it worked! While I was add it, I waxed the all the fiberglass gel doors with the same stuff.
Ed & Laureen
2005 F-250 4X4 SD 6.0 Powerstroke
2009 Cherokee Wolf Pack 285wp (the side door ramp toy hauler)
nailit is offline   Reply With Quote
Old 03-18-2012, 09:10 PM   #25
LKicklight's Avatar
Drip Gutter
Our new Crusader 270 RET 2011 came with them, but if its not perfectly leveled, ours is not, then you will get black streaks..ours run down the rear because the RV is parked in a nose high attitude and I can't seem to get it down low enough...so black streaks..
Good coat of wax helps in getting them off though..
LKicklight
LKicklight is offline   Reply With Quote
Old 03-25-2012, 06:25 PM   #26
Jeep4Two's Avatar
Tide (or other laundry detergents) will strip any wax, so be sure to re-wax after.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 04-07-2012, 12:22 PM   #27
Mountain Lovers
Cleaning of Black Streak and camper
We also use Awesome cleaner from the dollar store on the black streaks, Spic and span on the roof and magic erasures on the awning. They all do a great job. After washing we use Maguires to wax the nose cone of the 5er to keep off the bugs. Really helps alot!
Fordcamper is offline   Reply With Quote
Old 05-22-2012, 06:02 PM   #28
B47
...VTX-AL
Good advice - but If you do get them, I was told that using Mineral Spirits would get them off. I tried using it and it does remove them.
I got a bottle of MS at Wal Mart in the paint department in the solvent aisle.
Old 05-22-2012, 07:09 PM   #29
Stevea1956's Avatar
I've been seeing more and more RVs with full body paint and I wonder if some of these products will harm their finish.
Steve & Lauren
2011 Windjammer 3065W
2012 Ram 3500, 6.7 Cummins
Stevea1956 is offline   Reply With Quote
Old 05-22-2012, 08:44 PM   #30
DF5.4's Avatar
I have used Simple Green to clean the streaks. I have a few spray bottles with different strength mixes. I will start with the weaker mix and use full strength for the more stubborn streaks.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
