Old 05-20-2014, 12:52 PM   #1
fivecodys's Avatar
Removing Damaged Decals
After a few years the decals on the front and rear cap of the 5th wheel have started to peel.
The decals on the sides of the rig are holding up very well.
I decided that I would remove the damaged decals and replace them but after seeing the rig with out the decals I think I'm going to leave it as is.
I used an old hair dryer to heat up the peeling decals and they came off very easy.
I used a commercial adhesive remover to remove any glue left behind.
I plan to to use Meguires Cleaner wax this weekend to help blend in the areas that were protected beneath the decals.
I did a spot test by hand and it seems to work very well.
I will post a couple of pics when I'm finished and you can be the judge.
Have a great Memorial Day Weekend!
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 05-20-2014, 01:13 PM   #2
BiigDaddy's Avatar
Good info to file away... Thanks!
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
Old 05-20-2014, 01:13 PM   #3
the removal surface...is it fiberglass? I have some on the camping side that are cracked and need replacing, I have fiberglass
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 05-20-2014, 02:37 PM   #4
fivecodys's Avatar
Yep, fiberglass.
The hair dryer was the trick.
We have a heat gun at work I could have used but I was afraid that it might get a little too hot.
I used 'Rapid Remover' to remove the leftover adhesive. This stuff is way better than goo-gone. The smell comes off your hands easier too!
Bill
Air Lift 5000
Old 05-20-2014, 07:10 PM   #5
Thanks Bill I will give it a try
Jerry. Vietnam vet.
Retired
Old 05-21-2014, 07:37 AM   #6
tlambert's Avatar
If you need something good to remove glue and other contaminates try the 3M adhesive remover. I have used it many times and have had good results.
http://3mcollision.com/3m-general-pu...ner-08984.html
Tim
tlambert is offline   Reply With Quote
Old 05-21-2014, 04:20 PM   #7
fivecodys's Avatar
3M General Purpose Adhesive Cleaner Quart 08984
Hi Tim,
The company I work for has a division that produces vehicle graphics.
We have also used the 3M product and agree that it works well.
The Rapid Remover that I am using now has become the shop favorite mostly due to the smell.
It seems to be the easier of the three products (3M, Rapid, GooGone) to get the smell off your hands.
Have a great weekend!
Bill
Air Lift 5000
