So how well did the "whizzy wheel" work? My 2006 FR toy hauler's decals are dry and brittle however the glue seems to still be sticky as hell.
I'm prepping my 35ft Southwind for new paint, so I've been working a couple hours a night removing decals for the past couple weeks.
Painting 1999 Southwind – 1999 Southwind 35S
Three methods seem to work for me, depending on the decals condition.
1) Warm it up and pull it off - Heat the area then gently pull off the decal. This is the #1 chouice because it usually pulls the glue off also.
2) Eraser - The older and more brittle the decal, the better this works. Its slow but also removes the glue.
3) heat and scrape, this works on decals that have been painted over. Heat the decal then use a blade under it to peel it up, This doesn't remove the glue so you need to go back with glue remover to get the glue off.
