Old 12-19-2017, 11:12 PM   #1
AudiDudi's Avatar
Removing old decals
What's the best way to removes old, sun baked decals from the front of a 5th wheel. A heat gun worked great on the sides, but is not very effective on the front.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 12-20-2017, 08:40 AM   #2
Head Rambler
Many people swear by the 3M Stripe Off Wheels. They remove the decal without damaging anything.
Gotta go campin!
Old 12-20-2017, 08:40 AM   #3
SeaDog's Avatar
You might try some goof off and see if that will soften the adhesive along with the heat gun, this is just a guess on my part I'm sure someone on the forum will have a better solution for you
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 12-20-2017, 08:52 AM   #4
I just had the decals removed from my 2014 Flagstaff. Took it to Classic Fiberglass in Sanger TX. They did a great job. You cannot see where the decals were. They used some type of sanding wheel, then polished out the cap. They also did the entire camper, but the decals were the main reason. Super job by Classic.
sdfarmer is offline   Reply With Quote
Old 12-20-2017, 09:01 AM   #5
2007 WildCat 32QBBS
05CrewDually's Avatar
This is my goto for sticker removal too. All you need is a drill. I get the wheel and mandrel from my local NAPA but of course available at Amazon.
https://www.amazon.com/dp/B005RNGN8I..._EVMoAb4FDAYD0
05CrewDually is offline   Reply With Quote
Old 02-16-2018, 12:08 AM   #6
What decalers use to remove decals from trucks and trailers (18 wheelers) is a heat gun. Now I am NOT suggesting that you use a heat gun to loosen them up but rather a blow dryer. A heat gun produces too much heat that will not be safe for fiberglass or paint. Please DO NOT USE A HEAT GUN. The concentrated heat from the blow dryer will loosen the adhesive on the decal. I then use a PLASTIC paint scraper to lift the decal which usually comes off in pieces. For removing any left over adhesive, which most will be still there, I prefer to use a rag with gasoline to soak the adhesive and then use the PLASTIC paint scraper to help collect the adhesive. You will still need to use the rag to get some residual adhesive. Make sure that any heater, water heater, refrigerator, or other appliance, flame, and spark producing apparatus is turned off or nowhere nearby while using gas. And do not use the blow dryer again until any gasoline or fumes are gone from the site. Some will say that the use of gasoline is unsafe, and they are correct to a point, and that is their prerogative. Used in an unsafe manner it certainly is as is anything. As an alternative to gasoline you may want to try GoofOff, mineral spirits, alcohol, or kerosene, maybe even diesel.
2013 W&P 275ULSBS
2003 F-250 7.3L RWD
2009 HD Street Glide
ABFJV is offline   Reply With Quote
Old 02-16-2018, 12:45 AM   #7
Adhesive remover from any paint store will remove glue . soak with adhesive remover will be safer !
1999 dodge 2500 Diesel 4x4
2016 Wildcat Maxx
282rkx
aupainter is offline   Reply With Quote
Old 02-16-2018, 03:26 PM   #8
Both Goo Gone and Goof Off are considered to be "safer" products to remove adhesive but BOTH have labels that warn of using near sparks or flame (the same as gasoline). The only remover that I have ever seen that DOES NOT contain petroleum distillates is one of the "orange" based ones and good luck getting the adhesive off with one of those. Whatever you decide to use, it will probably be a petroleum based product, most are, be careful, try different products and see what works best for you.
2013 W&P 275ULSBS
2003 F-250 7.3L RWD
