Old 04-22-2018, 12:19 PM   #1
Replacement Kitchen Door
I was getting ready to wash my Heritage Glen 312QBUD. I use a foam canon on a pressure washer to do so. I had put the low pressure wash nozzle on to rinse it before soaping everything up. When I pulled the trigger the tip shot off and put a small ding in the kitchen door that was enough to crack the outer fiberglass. I want to get it fixed before the problem becomes bigger. Are the doors easy to change out and is there a good source for the correct parts online?
2016 Ford F350 Lariat
2019 Sandpiper 372 LOK
cstreu1026 is offline   Reply With Quote
door, replacement
