Replacing Cover Strip Where Nose Attaches to Roof
I was cleaning the nose of our 2014 Rockwood Signature Ultra-Lite 8282 Fifth Wheel and it looks like the plastic cover strip which covers the screw strip which helps attach the fiberglass nose to the roof is coming loose.
I was tempted to fill this area with self leveling caulk, but then again I guess I may just need to remove the old strip and install a new one. However there's no visible method of attaching this strip. Maybe it's glued or caulked on.
Does anyone have experience with replacing this plastic cover strip covering the screwed in aluminum strip where the nose attached to the roof?
I want to avoid any leaks and ceiling staining.
I have attached a photo of what it looks just slightly separated and then what it looks like if you lift up the plastic cover strip.
2014 Rockwood Signature 8282 Ultra-Lite
2008 RAM 3500 HD DRW Laramie Megacab
6.7 Cummins Turbo Diesel
