Old 10-21-2013, 01:17 PM   #11
Originally Posted by sail2liv View Post
I use what the dealer uses when they do a roof.....it is a one step clean and protect recommended to be done twice a year.....I would be careful with home mixtures as it may void the warranty if there is any....the dirty look is usually mildew and a protectant of a uv nature is required on roof.....good luck I hope mine will last the 12 years the warranty is for.....but there again....it can be pro rated....keep receipts and records of treatment purchased .....
What does your dealer use? Where can you get it?
I'm thinking the simple green/PP/Bleach combo is what I am going with.
2013 Rockwood Mini 2503S
2011 Chevrolet Silverado 1500 5.3L
Bryan2503S is offline   Reply With Quote
Old 11-11-2013, 02:08 PM   #12
I am taking a break right now from cleaning mine for the first time since I have owned it. It is a 2006 Rockwood 5ver which I have owned for a year and a half. Not real pleased with the results using a 50/50 mix of Simple Green and water. A lot of dirt is coming off but, it still has a lot of black streaks that will not come out. Not sure what to use but Simple Green did not get the job done.
RickV is offline   Reply With Quote
Old 11-11-2013, 02:23 PM   #13
John McClain's Avatar
I use a pressure washer and joy dish soap with a RV wash brush w/handle works great for me
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 11-11-2013, 02:27 PM   #14
I thought about doing that but, wasn't sure if the PW would damage the roof.
Old 11-11-2013, 02:58 PM   #15
Crusader's Avatar
I also would like to know what the dealer uses..... I would think bleach is not a good thing
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 11-11-2013, 03:14 PM   #16
rskrbina's Avatar
Originally Posted by jthomp58 View Post
Camping World carries rubber roof cleaner (Thetford) that will return it to that pristine white again. My husband has been using this product for a few years now and it does the job well.
I used this from Camping World. Did a great job. The camper is new this year but was pretty dirty by the end of the year.
Rudy and Jenny
2014 Flagstaff V-Lite 28WRBS
2013 F-150 Eco-boost 3.55
rskrbina is offline   Reply With Quote
Old 11-11-2013, 03:31 PM   #17
TURBS's Avatar
Soap n water.
Turbs
Old 11-11-2013, 03:32 PM   #18
TURBS's Avatar
Werks fine
Old 11-11-2013, 03:41 PM   #19
I went out and looked at what I had done compared to what wasn't (I was a little disheartened when it didn't look all bright white). Now that it is drying it is noticeably cleaner but still not as nice a Turbs so, I guess tomorrow I will go up and finish it. I think that those strains are down into the pores and only adding some bleach will get it Pearly White again and from what I've read that is not really good for the roof.
Old 11-12-2013, 01:39 PM   #20
I think you have to consider what kind of dirt has gotten onto the roof when you think about what you need to use when cleaning. Since ours tends to get sap & pollen, the Thetford Roof Cleaner will cut though the dirt. For others, simple soap & water may do the job if it is just dust & dirt up there.
jthomp58 is offline   Reply With Quote
roo, roof
