Old 05-09-2015, 04:45 PM   #1
Roof Cleaning
I'm sure it's been covered here, but I can't find this particular situation. The roof on our 2013 Georgetown has a one piece "pebbled" membrane. I'm sure the surface is to give better traction when walking on it, however it can be a real P.I.T.A. to clean well. I spent 4.5 hours up on the roof today with long handled brush, hose and sprayer filled with Awesome mixed 4 parts water to 1 part awesome. At the end, the roof looks pretty good, except there is some dirt, mold, fungus or whatever still present in the pebbling. I'm considering taking out my pressure washer and using the low pressure nozzle to try to clean it up better. Any ideas, pro or con? I'd appreciate any input. My Better Half says I am being too obsessive cause other people can't see it. I believe though that proper cleaning and maintenance prolongs the life of our belongings.
Clark Craven is offline   Reply With Quote
Old 05-09-2015, 05:05 PM   #2
Witch Doctor's Avatar
I would say no to pressure washing no matter how many PSI you set it for.
Coachmen M/H
Concord
2018 / 300 DSC
Old 05-09-2015, 05:17 PM   #3
Crusadernoob's Avatar
Wow, that sounds EXACTLY like my weekend last week, couldn't get mine "spotless" either. I also used awesome on it. All my wife said the whole time "don't waste too much time, no one will see it"
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37
Crusadernoob is offline   Reply With Quote
Old 05-10-2015, 02:29 PM   #4
It's most likely t p o you can use a weathered membrane cleaner never pressure wash I use spic and span in spring and fall and dawn dish soap in between if heavy sap or bird droppings I use a weathered me brain cleaner on a rag and wipe spots. If it was was a rubber roof acetone on a rag will work also on hard to clean spots
Clancy vibe272bhs
timothy clancy is offline   Reply With Quote
Old 05-10-2015, 04:09 PM   #5
Thanks for your inputs, I guess I'll just clean it a little more frequently and look into investing in a shelter, even though it doesn't sit very often.
Old 05-10-2015, 04:53 PM   #6
I cover ours with a breathable cover keeps leaves sap and bird droppings off after every trip I usually inspect it to make sure nothing was hit by a tree limb or any unforeseen hazards rinse off let dry then cover until next trip good luck and safe travels
Clancy vibe272bhs
Old 05-10-2015, 05:09 PM   #7
Cyber Phrenologist
Radio's Avatar
Yep. Don't let it get too dirty in the first place.
Also remember the point of cleaning the roof is two fold:
1. To make the roof membrane last longer.
2. To keep black streaks off the sides of the camper.
Once the roof is clean enough to accomplish these objectives, you're done. It doesn't have to look new. And be careful what you use to clean it with. Some things will shorten the life of the roof. Spic n Span and dish detergent are about all you should need.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
roo, roof
