Old 12-04-2019, 04:18 PM   #1
Roof decking separation
A few months ago I noticed the roof bowed out above the bedroom area of my 2018 Forest River Cherokee. I finally got around to taking it back to CW for inspection. Here's what the technician had to say:
ROOF IS WEAK AND SEPERATING FROM STUDS, MANUFACTURER LINED UP DECKING WRONG.
REMOVE TRIM, VENTS, AC, SKYLIGHTS AND PEEL BACK THE MEMBERANE. REMOVE DECKING REPLACE AND REINSTALL TO FIT CORRECTLY ON STUDS, LAY MEMBERANE BACK DOWN GLUED AND RESECURE TRIM, VENTS, SKYLIGHT, AC, ETC. WATER TEST SURFACE AND RE CAULK/
CW submitted a warranty claim to FR and it was denied (over 1 year mark). Anyone else run into this? I'm not prepared to shell out thousands of dollars out of pocket to correct a manufacturer defect.
2020 Ram 2500 6.4L
2017 Ram 1500 (Traded)
1991 Jayco 806 Deluxe
2018 Forest River Cherokee 264CK
Lektrikon is offline   Reply With Quote
Old 12-04-2019, 04:39 PM   #2
Did you contact Cherokee directly?
Do you have pictures of the area showing what's happening that you could send to Cherokee?
Gotta go campin!
Old 12-04-2019, 04:42 PM   #3
I have a VM in to the Midwest rep. Pictures were taken and submitted to FR already.
2020 Ram 2500 6.4L
roo, roof
