Old 08-04-2010, 02:22 PM   #1
Unhappy Roof Leak 2008 Rockwood 2701ss
Has anyone had this problem? Left back corner on roof is soft and mushy. I noticed that the trim piece on the ceiling in the back bedroom was coming off and water marks were on the top bunk mattress. Removed the trim piece and found water damage. So I climbed on the roof to inspect, found only the soft spot on roof. Any suggestions as to where to look for leak?
Melanie1 is offline   Reply With Quote
Old 08-04-2010, 03:14 PM   #2
There are many posts on here about roof leaks. I have seen posts where the water leaked in at the front of the trailer, traveled 30 feet along the roof to come out at the sky light in the bathroom in the rear. My unit is currently in the FR factory shop having the siding repaired for just such a leak. As for tracking down the breach allowing the water to come in, I suggest that you closely inspect all joints for cracks, holes, or voids. Many find that slideouts are a good source of leaks.
You can get a "pressure test" done at a dealer and that will enable the tech to locate the leak source. I have seen a post on here that someone has instructions on how to do your own pressure test.
Good luck.
Ray
grandpaofthree is offline   Reply With Quote
2701ss
