Old 05-07-2012, 06:24 PM   #1
roof leak
I have a 2007 surveyour 291 and the roof is leaking from the bathroom vent area. puddle on floor under this area. I took apart the fan and trim how can i test to see where water is coming from? the caulking is starting to crack? should i recaulk it? Do i just go over the old stuff or cut the old stuff out. i plan on using dicor self leveling
campfun is offline   Reply With Quote
Old 05-07-2012, 06:43 PM   #2
TURBS's Avatar
cut old out most defiantly !
Old 05-10-2012, 11:50 PM   #3
Cut out the old. If not it will still break down and the stuff you put over top of it will not hold up. It will start to break away.
2012 Coachmen Catalina Deluxe Edition 28DDS
2002 Cadillac Escalade
St1tcher is offline   Reply With Quote
Old 05-12-2012, 07:35 PM   #4
kevinC's Avatar
Yes, you should remove all the old caulk and sealers before applying the new. Make sure the surfaces are clean and dry.
2006 T23FBL Wildwood Lite
2009 Ford E-350 Super Duty 5.4L 3.73
kevinC is offline   Reply With Quote
