Old 05-23-2013, 07:10 PM   #1
Roof Material
In the owners manual download, the roof on Rockwood travel trailers is laminated material, 4" thick but it doesn't say how thick the plywood is, under the rubber roofing. Anyone know? Getting ready to put on solar panels and need to know how long wood screws can be.
Thanks.
wyoman is offline   Reply With Quote
Old 06-21-2013, 08:40 AM   #2
Never Leak RV Roofing
Usually 1/4" Luan.
rvroofer is offline   Reply With Quote
Old 06-21-2013, 08:58 AM   #3
10x
Good info in your site roofer
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 06-21-2013, 11:47 AM   #4
fredm.seven's Avatar
I have a 2012 Rockwood 2503S.
The skylight was just replaced under warranty, but before taking it in I saw that other folks had skylights replaced and had posted some photos. Check the skylight threads and you'll find those, but I took a look at mine before taking it in for repair.
At the skylight mine is a thin sheet of rubber then something like 1/8" of some type of fibre board, thick styrofoam, 1/8" of more fibre board, and vinyl ceiling sheet.
No plywood. Screws are held by styrofoam, at least at the skylight. There might be blocking (at least I hope) where heavier roof gear is currently mounted - I couldn't say.
Perhaps some other folks have have seen something different.
Fred
Fred, Gail and Sandee the Puggle
2008 Pathfinder, Native Ultimate 14.5, Delta 10
2012 Rockwood 2503S
fredm.seven is offline   Reply With Quote
Old 06-24-2013, 03:45 PM   #5
It should be 3/8.
whj77372 is offline   Reply With Quote
