Old 01-01-2014, 08:54 PM   #1
Average Joe
MrJoe's Avatar
Roof Radio Antenna Seal
Name:	ImageUploadedByForest River Forums1388630789.071414.jpg
ID:	44366Click image for larger version
Name:	ImageUploadedByForest River Forums1388630806.284320.jpg
Hello folks. I noticed my radio antenna was turned 90 degrees from before. Since I can't climb to the roof, I had a buddy check it out. Seems the antenna turns fairly freely at the base. I suspect a locknut came loose? We were in heavy rain last week and didn't notice any leaks. Should we be concerned? I can tell by the pics that the sealant moved. Thoughts? How would we tighten this up?
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 01-03-2014, 09:24 AM   #2
GM
bclemens's Avatar
My first thought is that it is a swivel base and they got a little too aggressive with the caulk (going up the side of the chrome shaft that swivels). But I'll go walk out on the line and take a picture...see how it mounts.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 01-04-2014, 07:59 PM   #3
Average Joe
MrJoe's Avatar
Thanks Mr C
Joe and Karen
Old 01-08-2014, 10:43 AM   #4
GM
bclemens's Avatar
I took a look at one online. The base plate is screwed into the roof. The antenna then screws into the base plate with a locking washer on the back side. I was able to tighten and loosen it just by spinning it. If it is real loose, just spin it clockwise to tighten, if the seal breaks, reseal. However I think the caulk will hold it where it is and you shouldn't have to do anything. If its pointing to the tail end I don't see it causing any issues.
Old 01-08-2014, 01:08 PM   #5
Average Joe
MrJoe's Avatar
Thank you for checking on that!
Joe and Karen
Old 02-04-2014, 01:11 PM   #6
On the same note: I have a unit that I bought used about three years ago. This past spring ('13) I was giving the roof a good washing and inspection. When the wash brush touched the radio antennae, which was straight up, the bottom of the antennae moved a bit. On further inspection I found that I could rotate the antennae base in both directions within the limits of the sealant that was put around it. As I started to remove the plate I noticed that the six (6) mounting screws did not have any sealant on them. It appeared someone had sealed the mounting plate to the roof and then inserted the screws. When I took the screws out all of them had practically rusted in two. Being as the radio in this unit didn't work I just removed the antennae and mounting plate altogether. An inspection of the area the screws were put into showed me that the wood underneath the screws had indeed rotted, so I assumed the screws had been leaking a long time. I cleaned the sealant off the roof area around the old mounting position, made an aluminum plate a bit larger than the original radio mounting plate, placed this on top of the rubber roofing which covered the hole of the original radio antennae mount, secured it with new stainless steel screws, and sealed this entire area.
Thurman is offline   Reply With Quote
antenna, radio, roo, roof
