Old 10-18-2011, 06:18 PM   #1
Roof Re-Seal of Cracked Dicor
I have been on the roof of my 2008 trailer and I have to think that the sealant looks pretty good. I found some small places on the end seals and a suspect spot on the antenna cord boot. I have small cracks in the Dicor but they only appear to be surface cracks and very shallow. It will only take a small smear to fill these cracks and do they really need to be filled? I want to eternabond the areas come spring and I don't want to put a large bead of Dicor on the cracks that I will have to try and cover up. I am attempting to post a couple of pictures that show the small cracks.
ID:	8686   Click image for larger version
jamesp is offline   Reply With Quote
Old 10-18-2011, 06:34 PM   #2
sherdep's Avatar
What are you asking?
Advice or just venting?
the cracks are probably not an issue but I bet the cord for the XM antenna is or is going to be - better seal at the least that part before it becomes an issue.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 10-18-2011, 06:51 PM   #3
Location: Canandaigua,New York (The heart of the Finger Lakes)
I'd hit where the XM cord is going into the sealant as mentioned by Sherdep- and the top part of the sealant in the first picture, otherwise your right, appears to be surface cracking...not bad!
David & Annamarie & 2-Pugs (Fatty and Harley)
2011 Rockwood Windjammer 3065
2011 Ford F-250 6.2- V8
2011 Hensley Arrow "NO-SWAY" Hitch
BigRed is offline   Reply With Quote
Old 10-18-2011, 07:06 PM   #4
Sherdep - I was looking for advice if I need to re-seal all of it or is it okay? No venting, it happens to all campers. I don't see how I can seal the small cracks without applying a big bead of Dicor or put it in the cracks with my fingers. The Dicor is thick and the cracks are shallow. I can imagine they will continue to crack deeper and have to be refilled. As stated in my original post, I plan to cover with eternabond in the spring.
Old 10-19-2011, 08:18 PM   #5
sherdep's Avatar
wasnt sure - hence why I asked - advice is always good
If it was me I wouldnt worry about the cracks but I would worry about where the antenna cord for the XM goes in to the roof before it leaks and not make it to your re-seal.
If you are going to re-do it with Eternabond - (I have never used it so cant give advice on that) I would caulk the antenna wire if nothing else.
