Old 06-13-2018, 12:19 PM   #1
Roof seams-any reason NOT to use Eternabond?
I am trying to identify any downsides to Eterñabond tape vs caulk on the 4 roof edge seams?
The only downside I have found is that it is a one time application and can not be removed/replaced. It can only be covered up. Given the tape's robustness, and longevity, seems pretty minor.
Just wondering why anyone would bother with caulk. What am I missing?
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 06-13-2018, 12:24 PM   #2
rsdata's Avatar
I wonder about that too...
going on 3 years with my Eternabond on the seams install... still looks the same as when I finished...
I have never recaulked as my install of E-bond was about 2 years from mfg date on my trailer...
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 06-13-2018, 12:43 PM   #3
David N Dianna's Avatar
We take delivery of our new Sonoma next week.
I ordered the Eternabond tape for the roof yesterday, that is the first thing on my to do list. Well maybe #2 new tires mount and balanced on the way home.
2018 Sonoma 201 Mt Edition
2003 Ram 4x4 2500 Cummns
David N Dianna is online now   Reply With Quote
Old 06-13-2018, 12:50 PM   #4
rsdata's Avatar
previous write up on Eternabond and roof seams...
Roof preventive maintenance
2014 Shamrock 183
Old 06-14-2018, 02:25 PM   #5
Eterna bond holding power
I used 2x6 inch strips of eternabond tape to hold down wires for solar panels on the roof of our Silverback, guess what? It does let go, lost 2 strips in the last 2200 kilometres. Roof was cleaned and applied on a warm sunny day! What did I do wrong?
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 06-14-2018, 03:10 PM   #6
patchman's Avatar
Prairiecamper, not sure what your procedure was but did you roll the tape after application? It’s the pressure from rolling the tape that activates the adhesive on the tape not necessarily heat from the sun. If you rolled it then not sure what caused your failure. Round trip from Regina, Sk to Mission, Texas and we had no issues.
Dianne & Dave
2013 Columbus 320
2014 Ram 3500 HD srw
patchman is offline   Reply With Quote
Old 06-14-2018, 05:37 PM   #7
Senior Senior Member
raytwntrvlr's Avatar
Watching this as I just purchased some eternabond with the same thought. I did use it when I installed a new fan on my unit and two years later it is holding just fine.
2015 Flagstaff Super V 26VFKSS Emerald
raytwntrvlr is offline   Reply With Quote
Old 06-14-2018, 05:50 PM   #8
rsdata's Avatar
what is a 2/6 inch strip?
put the eternabond the entire length...
impossible... if installed correctly... it does NOT let go...
mineral spirits to clean the roof then 93% IPA to clean off the spirits, let dry, and push or roll the Eternabond to the roof to adhere... nothing magic about this
2014 Shamrock 183
Old 06-14-2018, 06:53 PM   #9
It’s 2 inches wide and 6 inches long taped over a wire onto a cleaned rubber roof and rolled on with a seam roller on a warm sunny day!! The only thing I can think of is that the tape ( dicor ) I purchased was past its best before date because it didn’t stick to the roof like people here on the forum say it does. P.S. what’s IPA?
Old 06-14-2018, 07:37 PM   #10
kennyairport's Avatar
India Pale Ale don't waste it on the roof....
See you down the road. ;
Ken and Denise
2015 shamrock23s,2015 Ram Eco diesel
previous 1997 coleman highlander pup,1994 35rb Vectra,diesel,2007 Fleetwood arcadia pup.2005 ram
kennyairport is offline   Reply With Quote
Old 06-14-2018, 07:43 PM   #11
Now seriously what is IPA? cleaning agent? Oh Oh maybe isopropyl alcohol.
Ken and Denise
Old 06-14-2018, 08:18 PM   #12
Canadian Member
On another forum, one person who is a RV tech said he doesn’t like it because its too difficult to get off when he has to do a repair.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
itat is online now   Reply With Quote
Old 06-14-2018, 08:22 PM   #13
rsdata's Avatar
now that IS funny...
IPA Isopropal Alcohol... any drug store or Walmart or Dollar store has it in stock... different % strengths... I like the most percentage I can get usually 93%, but as low as 40%...
2014 Shamrock 183
Old 06-14-2018, 08:31 PM   #14
Ok India pale ale that’s what I thought of at first, nah can’t be LOL. ISO propol alcohol, I’ll give that a try when I get home.
Old 06-14-2018, 08:41 PM   #15
Just as confused as you
Scrapper's Avatar
I have the Alpha TPO roof on my trailer. I cleaned my seams with mineral spirits then wiped the spirits off with denatured alcohol. As your cleaning it just do a few feet at a time so the mineral spirits doesn't remain on the roof very long. Make sure you have plenty of rags. Once the roof is cleaned then start at the back seam, then the side seams, then do the front last. Over lap the side tapes on the rear tape and overlap the front tape on the side tapes. There is no need to remove the old caulking, place the eternabond right over it. Buy the roller and roll it down good.
I used 6" wide tape on the front and rear and 3" wide on the sides. Still looks great.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 06-14-2018, 08:49 PM   #16
rsdata's Avatar
To do THAT job I would use Gorilla Tape...
true story... 3 week trip in June to Sioux Lookout, Canada to fish, my live well pump broke on the trip up and left a neat 1 inch round hole below the water line to allow water to enter when launching the first day... Canadian friend says" I will whittle a plug" to push into the hole. I said "I brought a roll of Gorilla tape". I tore off a 2 inch by 6 inch piece, cleaned around the hole and taped over the hole on the transom of my aluminum boat. 3 WEEKS later... under water and near the prop of my 50 Hp Honda for much of the 3 weeks mind you... NEVER A LEAK nor any pulling off of that tape... I had to use pliers to pull the tape off the transom when I went to replace the broken live-well pump when I got home... as everyone knows, you can't use a live-well in CA anyway!
2014 Shamrock 183
Old 06-14-2018, 08:52 PM   #17
rsdata's Avatar
That is HOW to DO it RIGHT!
2014 Shamrock 183
Old 06-14-2018, 08:57 PM   #18
rsdata's Avatar
IPA was rubbing alcohol WAY BEFORE IPA was a popular style of beer... POPULAR I SAID... I know it was invented in like the 1800's... but not very popular with the beer drinking crowd until lately...
I currently like the Elysium Space Dust IPA...
2014 Shamrock 183
eternabond, roo, roof
