Old 11-04-2017, 07:07 PM   #1
john5646's Avatar
Roof stains, mold @ 4' seams
Ok so started some winter preparations today, started on roof and noted stain or mold at every 4' ... The pictures are after cleaning non prior, I expected to be able to remove them. Most came off but two areas remain somewhat unchanged.
This appears to be originating from between decking and covering, since it's such a defined line.
Any thoughts Click image for larger version
ID:	155759Click image for larger version
ID:	155760Click image for larger version
john5646 is offline   Reply With Quote
Old 11-04-2017, 07:15 PM   #2
Scoundrel
HangDiver's Avatar
Its hard to tell from the photos, and maybe someone with more experience can comment, but it looks like the mold is coming from the inside, out, as if moisture was trapped at the cross members.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is online now   Reply With Quote
Old 11-06-2017, 10:02 AM   #3
john5646's Avatar
This was forest river response.
Itís not mold. This happens on pretty much every unit. It is a chemical reaction between the glue and paint. It can be cleaned with bleach or spic-n-span/water solution.
If you have any other questions please let me know.
Respectfully,
Old 01-14-2018, 08:22 AM   #4
Captain Murica's Avatar
I've had that on pretty much every camper I have ever owned. I've tried scrubbing it with zero luck so I have just learned to live with it.
2017 F-350 Lariat DRW CC FX4 6.7L PSD with 4.10
2016 Salem Hemisphere 368RLBKH
Captain Murica is offline   Reply With Quote
Old 01-14-2018, 08:32 AM   #5
roof lines
I also have had the marks on every unit I have owned, some worse than others. It definitely is along the roof rafter lines. I would think an adhesive reaction would be on the whole roof though. The stain definitely comes from the joint in the plywood roof where the pieces join at the rafter though. I just wonder if the condensate/moisture from the interior of the camper is seeping through the plywood joint? It could be mold/mildew if this is the case !!!
Matheny9 is offline   Reply With Quote
mold, roo, roof
