Look at one of your other vents to see if it looks the same. Then you need to look very carefully at the hinge.. There are several different manufactures, but they all have a different hinges
__________________ 2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
Just found that my roof vent cover blew off and needs to be replaced. Can anybody tell me which part # or model replacement I will need?
Seal is still good around vent, so all I'll need is the cover.
After you find your vent cap and have installed it, then get one of these. This will keep your cap from damage and blowing off again. It will also keep the rain out even when the original cap it open.
