Old 06-10-2012, 07:41 AM   #1
David WAWA's Avatar
Roof vent cover installation help
I just purchased 2 roof vent covers for our TT one can be installed as directions show for the bedroom vent but the one that goes over the bathroom vent doesn't seem to work.The directions show mounting 4 brackets to the side of vent then installing vent on to brackets. As I said that worked for one. The bathroom vent is a power fan vent and I dont see how to install it this way. Any suggestions for install?????? Can I mount directly to roof and not side of vent???? If so help with that also.
David Walters
2012 2608 Rockwood Ultra Lite
David WAWA is offline   Reply With Quote
Old 06-10-2012, 07:45 AM   #2
sherdep's Avatar
which vents did you get?
I would not install it to the roof - as that will compromise the rubber membrane.
can you take pictures of the vents?
You may have to pull the fan section out and then re-mount everything
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 06-10-2012, 10:09 AM   #3
When I installed the roof vent on the power fan vent,I had to drop the inside panel with the switches to access the area to put the washers and nuts on.
09grizzly1
09grizzly1 is offline   Reply With Quote
Old 06-10-2012, 11:35 AM   #4
RoadDog66's Avatar
This is a MaxxAir II over my Fantastic Fan. Not sure what issues you are having, but maybe these pics will help. The brackets will sit about 1/4" high off the roof. One pic shows how much the lid opens with the cover over it.
Name:	Maxxair II install 13.jpg
ID:	15041   Click image for larger version
Name:	Maxxair II install 11.jpg
ID:	15042   Click image for larger version
Name:	Maxxair II install 16.jpg
ID:	15043   Click image for larger version
Name:	Maxxair II install 3.jpg
TV: '15 Ram 6.4 Hemi CC 4x4
Old TT: '12 Rockwood Roo 19 (sold)
New TT: '14 CR Sunset Trail 290QB
WD: Equalizer 1200/12K
BC: Ram OEM
RoadDog66 is offline   Reply With Quote
Old 06-10-2012, 03:46 PM   #5
David WAWA's Avatar
Thanks for the pics thats exactly the same vent Im dealing with, What I dont see is how the brackets are secured the the plastic vent itself ? Do you have to remove power vent to install brakets
Old 06-10-2012, 04:05 PM   #6
You don't have to remove anything. If you have MaxxAir covers the bracket has holes that you can see in RoadDog 66's first picture. Predrill a hole and use included screws or nuts and bolts to secure the bracket to the plastic lip of vent. See picture 2a of the instructions.
Old 06-10-2012, 04:18 PM   #7
David WAWA's Avatar
My vent cover is a Caper World cover but it does have the same brackets.I installed the first one and it bolted into the metal frame. The picture above is the same power vent I have and Im just not sure about installing the brackets to the plastic frame which is also wider then bolt length provided thats why I asked if it needed to be disassembled in order to bolt on brackets
Old 06-11-2012, 08:55 AM   #8
RoadDog66's Avatar
The Fantastic Fan on my Roo has an all plastic surround and was easy to drill through. The bolts provided with the MaxxAir were plenty long enough. Maybe you just need to buy some longer bolts. The fan itself stays in place and doesn't need removed. I just opened the fan cover, climbed on the roof, drilled the holes and installed the brackets. The MaxxAir II has a hinged side that allows the cover to open to one side for cleaning, not sure about the Camping World one. Best of luck.
BC: Ram OEM
Old 06-11-2012, 09:48 AM   #9
2011 Berkshire 390BH
Superchief's Avatar
I have power vent fans that I recently installed the Maxx Air II on. I had the same issue until I noticed the supplemental instructions on the paper cover that came with the fan. I used the small screws to install it. You need to be very careful in drilling the holes to avoid hitting any of the electrical connections. Also the hole to predrill is smaller than the bolt holes. When I purchased the unit, these instructions for mounting on power fans is not clearly evident, at least they were not to me. I had all of the stuff on the roof and was ready to go, but initially ran into the same problem as you. Covers work very well. Good luck...
Craig
Finally completed all State visits in August 2011 with a trip to North Dakota.
Superchief is offline   Reply With Quote
