Old 05-23-2012, 05:16 PM   #1
roof vent replacement
I am in the process of replacing one of my roof vents. it was leaking. found a crack in the plastic frame.. I replaced with a new one. Now that I went to screw down the vent it wont get tight. the screws seem like they wont grab.. only thing there is the the 1/4 plywood and the styrofoam insulation for roof.. any suggestions on how to get this tight?
or should i tighten down best i can and put lots of caulk to seal it up good?
I have a 2007 forest river surveyour 291?
campfun is offline   Reply With Quote
Old 05-23-2012, 06:01 PM   #2
TURBS's Avatar
try a bigger screw ? not longer but bigger in diameter .
Old 05-24-2012, 07:23 AM   #3
Dallas Texas
TexasBBQ's Avatar
Once you add the Dicor it'll be secure.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 05-30-2012, 06:49 PM   #4
thanks guys. i finished the repair and got its first water test and no leaks> that is great and was easier than i expected. thanks for the help.
Old 05-30-2012, 06:51 PM   #5
TURBS's Avatar
no problem !
Glad ya got it !
