My roof is TPO , l use Acetone, but l also use Eternaprime that l apply with a brush, l don't use the spray can because l want a good application, let it set for 20 minutes and place the Eternabond, its definitely going to stick so go slow with the Eternabond ,you want get a second chance, if you do get off line with your Eternabond l just cut it off and overlap about 6 inches and straighten my line up. Acetone will clean it well, apply it to your rag that you are cleaning with and wipe good, if it's really dirty you might want to take some soapy water ( dish detergent) and wipe as much as you can first, good luck, happy camping.
