Old 09-03-2017, 10:40 PM   #1
brad10281's Avatar
Roofing sealant...what is this?
What product is this?
As you can see, it's cracked and needs replaced. This stuff is on all 4 corners and it looks about the same at all 4 corners. I filled the gaps with silicone (only thing I have at the moment). I want to get this off and replaced with something better or at least reapply what's there...but I don't know what I'm looking for.
What's the best product to use here?
Brad & Gail
2014 Chevy Silverado 1500 Z71
2015 Shasta Flyte 255RS
brad10281 is offline   Reply With Quote
Old 09-03-2017, 11:52 PM   #2
FrankG's Avatar
I have no idea what was used to do the repair. The end of the trim piece is a common failure point on FR products. I would dig it out and replace with Dicor self leveling sealant. Check the type of roof you have.
2018 Haulin 6 x 12 Cargo Trailer by Forest River (A legal Tow )
2017 Laredo 325RL
2016 Vengeance 29V Sold
2016 Ram 2500, 4x4 Laramie CCSB 6.7 Cummins
FrankG is offline   Reply With Quote
Old 09-04-2017, 12:11 AM   #3
Novice Travel Trailer Guy
benchmarks's Avatar
It's lap sealant. Was most likely one used for EPDM. If your trailer is then they just used wrong color for whatever reason. If your cap is a tpo thermoplastic then it's the wrong type of lap sealant. It's not made for a rubber sealant.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
Old 09-04-2017, 12:14 AM   #4
benchmarks's Avatar
Dicor is good. Many to choose from. Don't use silicone.
Old 09-04-2017, 09:35 AM   #5
brad10281's Avatar
Thanks guys. Whatever this black stuff is, it is still very pliable and doesn't stick to the roof very well at all. I could literally peel it off, ball it up and reapply it. Sounds like lap sealant is the product of choice here. Heading to CW here shortly to pick up sealants.
Brad & Gail
Old 09-04-2017, 11:01 AM   #6
ejohnson1144's Avatar
That is duct seal used in the electrical industry to seal penetration of wiring
ejohnson1144 is offline   Reply With Quote
Old 09-04-2017, 11:03 AM   #7
brad10281's Avatar
Hah, I got some of that laying around...but I'll go with something different!
Brad & Gail
Old 09-04-2017, 11:06 AM   #8
I would never use on an RV
Old 09-04-2017, 11:41 AM   #9
Just as confused as you
Scrapper's Avatar
If I were you I'd clean that off and wipe it down with a rag and lacquer thinner, don't let the thinner stay on too long or it will soften the roofing material. Put dicor on it and go along the grooves in the vinyl insert until it starts on the downward slope. After it sets up get some EternaBond tape (https://www.eternabond.com/) and cover all the seams on your roof.
EternaBond works with all types of roofs and pretty much guarantees against leaks. Many people do their roofs with it as a preventive measure. I've done it to my roof and it works great.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 09-04-2017, 12:40 PM   #10
Scrapper's Avatar
Never use silicon on your RV. What you see on your unit that you think is silicon is actually Proflex Sealant, by Geocel. It looks like silicone, but it's not.
https://www.geocelusa.com/product/pr...xible-sealant/
Richard & Jill
Old 09-04-2017, 01:13 PM   #11
X2 on the eternabond. Just make sure all of the silicone is removed because eternabond will not stick to silicone. I also used dicor self leveling caulk on the edges.
Bnrc73 is offline   Reply With Quote
Old 09-04-2017, 01:35 PM   #12
what is wrong with using silicone? I am an idiot when it comes to all these different products. If the label says its ok, I buy it. Not the best thing, but I have no knowledge on an abundance of things. Hardware stores want to sell, even when you explain the problems.
grandpamuck is offline   Reply With Quote
Old 09-04-2017, 01:39 PM   #13
Dicor is the product recommended by the company's that make the roofing systems used in the ft industry. And it doesn't work well with standard silicone.
Old 09-04-2017, 04:57 PM   #14
don't use silicone. it won't seal for long. Dicor self leveling sealnt is great and very sticky. paint thinner for clean up. wire brush on drill to remove old stuff.
jrowe0521 is offline   Reply With Quote
Old 09-04-2017, 05:14 PM   #15
rsdata's Avatar
X3
EternaBond
How many Amazon products have 96% 4 and 5 stars?
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 09-06-2017, 02:24 PM   #16
Filterman's Avatar
Ditto. Decor self levelling works great for any horizontal roof joint.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights
2016 96 nights .2017 72 nights. 2018 157 nights
Filterman is offline   Reply With Quote
Old 09-06-2017, 02:37 PM   #17
brad10281's Avatar
I'll have to take a better pic and share it. This stuff is plastered all over each corner. Planning to remove it and seal everything up appropriately.
Brad & Gail
Old 09-06-2017, 02:50 PM   #18
Eternabond for the win!!!
2019 Silverado 1500
No camper, currently
polishdon is offline   Reply With Quote
Old 09-06-2017, 02:54 PM   #19
Brother Les's Avatar
I have seen in RV stores that sell several type of sealant. the rubberized type flows and levels out and goes on the roof. I think that you have there on the side a type that can go across the top and edges and not 'run' or drip and does not 'dry out' and stays pliable. It comes in different colors of white/black/brown.
Brother Les
Old 09-06-2017, 03:14 PM   #20
I feel that if you some sealant into the pre-drilled hole, there would no way for water to get in. At least sealant around outside of hole before mounting bracket.
roo, roof, seal
