Old 05-08-2013, 08:13 PM   #11
LKicklight's Avatar
Cover
Purchse the Crusader 270RET a year ago..also bought an ADCO Designer Series 5th Wheel Cover for it..took us a year to finally get it on...wish we had done it sooner..really does a great job in keeping the top cleaner and the sides as well..Do get the ADCO with the Tyvek Roof...more money, but well worth it..it fits well and having the zippered sides really works well in getting in and out during the winter months or just sitting between outings..
Originally Posted by Frank-VA View Post
We looked into a cover. Talking with other RV owners some say that the covers can rub the finish on the RVs. We decided in a Metal pole building.
Ours is 15' tall x 18' wide and 36' long. You can check out the following web site: Pole Buildings | Steel Pole Buildings | Newmart Builders Inc.
We went straight to the Newmart Builders and purchased it. It took the contractors (3 persons) 3 1/2 hours to set up
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 05-09-2013, 10:17 PM   #12
Smile
We have a Sunseeker 2860 and I did a lot of research on RV covers and decided to spend the extra bucks on a Calmark cover. In Colorado we usually store the RV from about Oct till May so it's worth it to us. Kinda pricey but you get what you pay for..beside it's Made in the USA.
Get on their web site and ask for a sample package.
Wildkats66 is offline   Reply With Quote
Old 05-10-2013, 05:02 AM   #13
Old car's Avatar
We ordered and use the Calmark cover as well. With the v-nose trailer it was custom made and fits like a glove.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 05-10-2013, 05:46 AM   #14
Originally Posted by LKicklight View Post
\..really does a great job in keeping the top cleaner and the sides as well..Do get the ADCO with the Tyvek Roof...more money, but well worth it..it fits well and having the zippered sides really works well in getting in and out during the winter months or just sitting between outings..
X2 We have the same on our TT and very happy with it so far. I do wish I could get it as tight and smooth as the one in your pic you. Mine bunches up around the axles.
Len & Cheri is offline   Reply With Quote
Old 05-10-2013, 10:01 AM   #15
VinceU's Avatar
Best application of cover i've seen to prevent billowing and tears:
Obviously cover all edges and corners with noodles or tennis balls. Apply cover
Tie down with inexpensive web belts/ratches at 3 or 4 locations across roof, down siides and across bottom about 40' each as a girth belts.
Lastly add a longer longitudinal belt front to back and return to front and secure. This belt would be abot 80' made with 15 or 20' secrions. Can buy webinf with ratchets in Wmart or dollar+ stores. Works better than finding your 300+ cover in shreds!
Old 07-24-2013, 11:01 PM   #16
Take The Road Less Travld
MuddauberE's Avatar
Seems like most people cover their trailer. I have been trying to decide if I was going to or not. Maybe I should. I have a 2013 Roo. Upgrade from a popup trailer that I wish i kept covered. One question, how do you deal with the radio antenna on the roof? Do I just bent it over or does it remove?
"Take The Road Less Traveled"
2013 Rockwood Roo 233s
2017 Ford F-150 EB
I've been an RVer since 2007, Lifetime Camper
Gotta love the Outdoors, Disconnect and Enjoy Nature!
MuddauberE is offline   Reply With Quote
Old 07-25-2013, 05:03 AM   #17
Oaklevel's Avatar
Actually most people do not cover their trailers you just hear from the people that do. If you live in an area that is windy I personally do not recommend it. Covers don't last long & can cause paint damage. ( Mine lasted less than 3 months) If it is not windy it is up to you...........
Most RV people I know that have bought a cover either use it once & trash it or after the first season never buy another........
Good Luck......
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 07-25-2013, 06:15 AM   #18
I covered mine this past winter and it worked great. Keep the unit clean with all the snow ice and rain we had thru the non-camping season. My TT is not that big so it is easy to cover. I did put tennis balls on the gutter spouts and on the awning lever. The radio antenna lays flat. There is a screw on the adjustment ball, so loosen and lay flat.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 07-25-2013, 02:22 PM   #19
MuddauberE's Avatar
Thanks for the input. I will look at the antenna. I live in Ohio so you never know what the weather is going to be like. It can be windy but not for long periods of time. Your talking more of a storm and that's it. Nut the constant rain, ice, snow the sun, then snow again make me concerned about expansion and contraction of items on the roof. Just wanted to know what others did.
2017 Ford F-150 EB
Old 03-10-2014, 08:03 AM   #20
Originally Posted by Old car View Post
We have a v-nose trailer so we had to order a custom cover to get a good fit. We have covered it for two winters and have no affects from rubbing. I do admit, we park it where the north wind cannot get to it behind our barn. Before you ask--the barn isn't tall enough to park inside. Built it before I ever thought I would own a trailer. Tennis balls on the downspouts. I'm glad we made the investment. Make sure your cover can "breathe".
OLD CAR--Where did you find a cover for the windjammer? I have a 2010 winjammer and can't find one unless I have it custom made.
brianq9 is offline   Reply With Quote
