Old 04-02-2015, 06:18 PM   #1
Evo2700's Avatar
RV Cover With Solar Panels
Here is the dilemma:
I recently invested in solar panels to keep my batteries charged when in storage. Since I won't be using the trailer much this year due to my wife being pregnant, I wanted to get a cover so my new TT doesn't bake in the NV sun this summer.
Do I cut a hole in the cover for the panels, which will void the cover warranty?
or
Completely remove the batteries and throw them on a battery tender in the garage, which makes me feel like I wasted my money on the solar panels?
2015 Evo 2700
2017 Ram 2500 6.4 Hemi 4.10
Evo2700 is offline   Reply With Quote
Old 04-02-2015, 06:24 PM   #2
Boss Hoss's Avatar
Removed the batts and put them on a battery maintainer-not a battery tender.Big difference.
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 04-02-2015, 06:35 PM   #3
geotex1's Avatar
Store the batteries. To put holes in the cover, you'll need to have them reinforced and edged or your cover will shred with minimal wind unless you're starting with a $1K Sunbrella fabric Calmark custom or similar.
geotex1 is offline   Reply With Quote
Old 04-02-2015, 07:42 PM   #4
Evo2700's Avatar
IF I were to cut it, my wife would sew in reinforcement, but that would void the warranty. I wonder if enough light goes through where the panels would still work....just thinking out loud.
2015 Evo 2700
Old 04-02-2015, 07:58 PM   #5
geotex1's Avatar
Originally Posted by Evo2700 View Post
IF I were to cut it, my wife would see in reinforcement, but that would void the 4 yr warranty. I wonder if enough light goes through where the panels would still work....just thinking out loud.
She happen to be a canvas maker? Not being flippant, my brother is and to stitch in what you'd need to keep it together with the fabrics used in the less-expensive covers is a bit more than the home sewer can usually do.
I'm not a solar guru by any means, and you are more knowledgeable of your particular panels. However, no matter what you'll be severely inhibiting their performance. I know some are good with indirect sunlight, but seem to think all still warn against dirt and its effect. Even the most opaque fabric - Tyvek - is as bad/worse than a dirt film I'd think... I'd also wonder about the heat. We can fry an egg on any panel in the 10kW array just with the morning sun.
If you pay the premium for a custom cover (like a Calmark), they'll do the holes, reinforce them, and give you the 6 year (I think that's theirs) warranty.
Old 04-03-2015, 06:32 AM   #6
RPAspey's Avatar
There was a thread on this very topic some time ago. I believe that OP ended up trying the cover on top of the panels.
If your cover lets some light in, and your panels capacity is enough I think the panels should produce more than enough power covered, to keep the battery charged during storage. Hey, why not try it and see. My panels were producing power with 6" of light snow on them during a sunny day. Now it wasn't much, but enough to trickle charge the battery.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 04-03-2015, 12:43 PM   #7
store the batteries
wire1946 is offline   Reply With Quote
Old 04-03-2015, 03:18 PM   #8
Portable Solar
"Do I cut a hole in the cover for the panels, which will void the cover warranty?"
One solution I've seen is the purchase of a smaller, portable solar panel. I don't need one, but my solar panel has a plug that would allow an additional solar panel to be attached. You can find them on Google.
lacamastraveler is offline   Reply With Quote
cover, solar
