Old 10-28-2013, 01:54 PM   #1
Wafer's Avatar
RV Roof Vent Covers
Looking at putting roof vent covers over the existing roof vents on my trailer. On previous trailers I have installed the original style Maxxair vent covers, then on my previous trailer I installed the older style Camco vent cover. Now looking at the Camco Aero-flo RV Roof Vent Cover. Does anyone have experience with them?
Wafer is offline   Reply With Quote
Old 10-28-2013, 03:26 PM   #2
Denver, CO
garbonz's Avatar
I used fantastic vent covers, they are EASY to install and have better flow than the others, at least according to the cute little video on their website.
2017 Fuse 23T
Old 10-28-2013, 03:29 PM   #3
Denver, CO
garbonz's Avatar
http://www.fantasticvent.com/products/ultrabreeze.html
2017 Fuse 23T
Old 11-17-2013, 01:09 PM   #4
I am in the process of changing mine. The regular vents went easy with the Camco ones. You have to put new brackets on because the hold down bolts are on the outside. The problem I have run into is I have a fan vent in the terlet and can't figure out to get the bracket screws out to put in the new brackets there is no way (at least that I can see) to get to the nuts on the inside where the fan is. The vent cover that is there bolts on the inside of the vent cover. I thought about just ordering one of those but, I can't find em anywhere they are called Zero Flo. Anyone know where I can find em or similar ones so I don't have to change the brackets? It is a 2 piece thing where the top lifts off.
RickV is offline   Reply With Quote
Old 11-17-2013, 05:05 PM   #5
Never mind I am dyslexic or just stupid take your pick. It was Aero Flo not Zero Flo. One of the vents I replaced with the Camco one is in pretty good shape so I will use it for now as we are heading out Wednesday for a 10 trip I will order and replace it when I get back. I still would like to know how you get to those bracket screws in the fan vent out though.
Old 11-17-2013, 10:07 PM   #6
Wafer's Avatar
Thanks for the heads up Rick. If you are having trouble with the Aero-Flo I question whether I want to. My last trailer I used the regular Camco vent covers and when I went to remove them all if the carriage bolts rounded the openings in the aluminum brackets. Good thing I was able to complete the repair without requiring removal of the cover. Thank god the screen could be removed easily. I think it is looking like the Maxair.
