Old 09-04-2017, 08:20 AM   #1
sonic2's Avatar
RV Wash - What to you use?
I've done a search, but not did not find the information I was seeking. This is not a question about the roof, but the exterior sides. Does someone have a good reason for using a certain product and not using a certain product. I use NuFinish for the wax and Murphy's Oil Soap for the roof, but that's not the question either, I'm only concerned with the soap to clean the RV.
What RV Wash do you use and why and/or why not using something?
A few name brands are:
Thetford
Star Brite
BEST
Camco
Gel Gloss
There are wash and some that are wash and wax. I've used Thetford Wash and Wax for years, but I may be changing brands.
2014 Rockwood 8289WS - Goodyear Tires
2013 F150 crew 4x4 5.0L 3.73 6 1/2 bed
Supersprings & Timbren & B &W Turnoverball
Anderson Ultimate 5th Wheel Connection Hitch
sonic2 is offline   Reply With Quote
Old 09-04-2017, 08:23 AM   #2
Bikersarge's Avatar
I use regular car wash, then I put F-11 topcoat sealant on her.
Not Camping enough Need therapy
2013 Forest River Salem/Sport Fifth WHL
2017 GMC Sierra 2500 Duramax/Allison
Curt Q20 Fifth wheel, Champion Inverter3500
US Army Retired
Bikersarge is offline   Reply With Quote
Old 09-04-2017, 08:35 AM   #3
007matman's Avatar
I've always heard to treat it just like you would your car. Don't use anything that would strip the finish. Waxes that you put on by hand (or using a buffer) will generally last longer but they are more work.
I don't use any of them that have waxes built in because I hand wax mine.
This is what I used last time. So far so good.
Meguiar's M-5016 Boat/RV Cleaner Wax - Liquid, 16 oz. https://www.amazon.com/dp/B0000AXMY8..._VzvRzbTM72F1X
007matman is offline   Reply With Quote
Old 09-04-2017, 09:12 AM   #4
ejohnson1144's Avatar
I have a forest river product and forest river recommends a mixture of Johnson's baby shampoo and vinigar and water . don't know why.
Sent from my LG-H910 using Forest River Forums mobile app
ejohnson1144 is offline   Reply With Quote
Old 09-04-2017, 12:35 PM   #5
re
I use Thetford wash and wax and apply it with my pressure washer and rinse it off with low pressure. If I'm inthe mood I put a coat of Liquid Glass on the cab.
poppytoymaker is offline   Reply With Quote
Old 09-04-2017, 12:46 PM   #6
Mountainmanbob's Avatar
Dawn
Works great.
Even safe for use on animals.
M-Bob
Mountainmanbob is offline   Reply With Quote
Old 09-04-2017, 12:57 PM   #7
D W
D W's Avatar
Thetford
Star Brite
BEST
Camco
Gel Gloss
Logically speaking, I don't believe that there is any one product out there that will suffice everyone's requirements. We live on a vast continent which contains some of the most diverse geographic and climatic conditions. The OP lists Nebraska as there base. What will work for the OP in Nebraska may not be the best for someone based out of Montana or Arizona. Conversely, the products and processes used in the latter may not be the best for Nebraska. We are all "travelers" and tend to cross over into other climates with different types of natural "fallout". So, you may have to amend your cleaning process with different products from time to time. I will state for the record that I stay away from "waxes". I also steer clear of RV branded cleaning products. Just another way for the industry to take your money.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
1984 CHEV SCOTTSDALE K20 2GCGK24J0EXXXXXXX (Chevrolet Legends-Class of 2019)
D W is offline   Reply With Quote
Old 09-04-2017, 01:10 PM   #8
True, but if It saya for Gel-coat I have to think twice
Old 09-04-2017, 01:16 PM   #9
as a follow up. it has been stated that using a power washer. In past posts things have been mentioned about the graphics being treated differently than the coach. How are the graphics ignored if using a power washer or hose. I am not saying this is wrong, I just don't want the graphics being damaged sooner than their lifetime expectancy. I also want to do it the easiest way possible.
grandpamuck is offline   Reply With Quote
Old 09-04-2017, 01:29 PM   #10
You use power washer soap nozzle to spread soap then convert to water with same nozzle and it's low pressure to wash soap of. Use soft brush on a pole where needed
Old 09-04-2017, 01:41 PM   #11
Regular washing with an inexpensive Car Wash/Wax product will do a lot for preserving the appearance of the RV. A gallon of Car Wash/Wax from your favorite Auto Parts Store or Walmart is inexpensive and the primary benefit is that most contain simple anti-spotting additives.
Buying washing products with RV branding is like buying shampoo in a Barber Shop/Hair Salon. Same basic stuff with more profit for the seller.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 09-04-2017, 01:42 PM   #12
Depending on how dirty my RV or car is I use a waterless product called The Solution. It is perfect for Gel-Coats.
After "washing" mine once in an RV park a guy came over telling me he owned a Napa Automotive store and he had nothing that worked as well as The Solution.
In fact, when I was full-timing on the DP I would carry a couple extra gallons because I was often able to sell a gallon or two at a profit if people saw me using it.
And it really works great on windows. After using bugs easily wash off.
Anyway, here is information from Amazon
https://www.amazon.com/s/?ie=UTF8&ke...ijghfiiw_b_p19
lacamastraveler is offline   Reply With Quote
Old 09-04-2017, 02:07 PM   #13
Delco Bobby's Avatar
Originally Posted by Mountainmanbob View Post
Dawn
Works great.
M-Bob
I have an area above the cab that the RV washband wax was leaving dirty. I used Dawn on it yesterday and now it is clean.
You can add some vinegar to the Dawn solution to help with spotting.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 09-04-2017, 03:16 PM   #14
I use regular car wash and gel gloss for black steaks.
markb422 is offline   Reply With Quote
Old 09-04-2017, 03:34 PM   #15
I have had great luck with this product. One step, wash, and wax. I have been using it for about 4 years and it never fails when I am camping someone asks how I keep my rig so shiny. I use this and when I arrive at the camp site I use a California duster.
Gel-Gloss RV Wash and Wax - 128 oz Online - IS dealz
Airborne is offline   Reply With Quote
Old 09-04-2017, 04:49 PM   #16
SailorSam20500's Avatar
There was a session at the Goshen rally this year, with Todd Breden (FR Prime Time) on fiberglass and paint. He specifically said NOT to use Dawn on fiberglass. He is aware of or has done tests that showed that Dawn will "eat" the fiberglass. It gets into the pores of the fiberglass and does its damage. His specific recommendation was to use your favorite auto wash. He did call Maguires and Mothers out as good wax products and recommended Maguires as having the best bang for the buck.
Al
Save the Earth. Its the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 09-04-2017, 05:08 PM   #17
old40ford's Avatar
Dawn or any dish liquid will strip all the natural oils from the paint and eventually ruin it. Don't believe me, check with a paint manufacturer.
Retired Auto body teacher/Retired RV Dealer GM
2017 Puma 255RKS
2019 F-250 Lariat Super Crew 6.2
No Kids
No Pets
But lots of Fun traveling with my wife
old40ford is offline   Reply With Quote
Old 09-04-2017, 05:21 PM   #18
We've been using both GelGloss and Thetford products for more than 30 years. I used Gel Gloss Wash and Wax on my previous TT for 12 years, and when we traded it in, the dealership said t looked almost new. My technique was to put 2-3 oz. in a bucket and half-fill with warm water. Using a wet towel on one section of the side wall at a time. Then wipe it dry with a clean, dry towel. Always left a smooth, dry surface with no streaks. Roughly twice yearly we would also wax each section the next day with Gel Gloss Polishing Wax. Time consuming and labor intensive, but it gives you the opportunity to look closely at every square inch of your RV to check for dings or scrapes.
Jakie-Boy is offline   Reply With Quote
Old 09-04-2017, 05:38 PM   #19
BamaBob's Avatar
We use waterless - so we can clean the coach even in a RV Park that does not allow washing.
Best stuff out there is Wash Wax All - the more you use it the better it protects - so well that June Bugs literally fall off the front of out coach.
https://washwax.com/
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 09-04-2017, 06:36 PM   #20
That stuff is pricey! How much do you need to clean your-sized trailer and what size is it? Thanks.
eye95 is offline   Reply With Quote
