03-12-2017, 03:19 PM
Safe to walk on roof to clean?
I have a 2012 Wildwood X-Lite 261. I want to clean the roof. No ladder installed on RV so I am assuming the roof may not be safe to walk on? Does anyone know? If not, do I clean it from a ladder?
Thanks!
2019 Rockwood 2707WS
2009 Ram 2500 5.7/3:73
03-12-2017, 03:42 PM
unless your a big guy, no reason you can't walk on it, but do it gently with soft sole shoes
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
03-12-2017, 04:06 PM
And who is going to see a dirty roof? Only reason to go up there is to check integrity or patch a leak.
03-12-2017, 04:12 PM
everyone sees it, because it leaves streaks down the sides
03-12-2017, 04:14 PM
Actually keeping the roof clean by washing it on a regular basis is the first step to keeping the whole rig cleaner
All that gunk comes off the roof down the siees
03-12-2017, 04:40 PM
Yup the black streaks on trailers is a direct result of the roof, not the trailer itself. Whether you have the ladder or not does not impact the integrity/construction of the roof....totally fine to be up there.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
03-12-2017, 04:47 PM
I so apologize for my comment about not cleaning your roof...but then again, I've never had a 'streak'.
03-12-2017, 05:51 PM
Thanks everyone. [emoji6]
03-13-2017, 12:04 PM
With all that I have heard, read and seen I have to wonder if keeping the roof clean is a stipulation in the warranty that might void the warranty if it's not cleaned at least twice a year?
03-13-2017, 12:18 PM
Not necessarily true. If you have an EPDM or other rubber roof they need to be cleaned and treated a couple times a year at least.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-13-2017, 12:45 PM
Be careful! A wet rubber roof is like a hockey rink!
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
03-13-2017, 01:12 PM
Twice a year is good for both cleaning and inspection.. I use Dawn for cleaning.. plus I can see the 54ver roof from the 2nd floor of my house and the streaks bother me.
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
Month of July in the Egg Harbor Campground, Door County, WI
5 stars
03-13-2017, 01:52 PM
Ideally you may want to time your roof cleaning along with waxing, because as was suggested where Dawn is a good soap to use to clean the roof it will also remove the wax from the trailer.
03-13-2017, 02:31 PM
Fantastic is also approved by Dycor to use on rubber roofs. Muchg cheaper than the "specialized" products sold by Camping World
Kayo
03-13-2017, 02:48 PM
This has always been a question mark in my mind. The Forest River users manual states that if a manufacturer installed ladder is present then the roof has been reinforced and it's safe to walk on it. It goes on to say, if a ladder is not present then you should use boards across the roof for temporary reinforcement. As a result, I've erred on the side of caution and always put boards across my unit when doing maintenance. It's a pain in the neck too.
However, when we did our PDI, I went up there when they were checking the seals and we were all walking on it with no problem. I asked the guys then if it was ok and they said it's no problem but try to limit the time spent on the roof to a minimum. Again, I've since just put boards up as a precaution.
03-13-2017, 05:28 PM
Fantastic cleans the black streaks off easy.
Jim
03-13-2017, 05:49 PM
If one cannot walk on the roof, you do not want the RV.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
04-06-2017, 07:49 PM
So after going up there without the boards, are you still using boards? Or do you think its unnecessary to use boards?
07-13-2017, 01:17 AM
Not sure how old this post is, but I have s FR 5th wheel without a ladder and FR says it has a 200lb weight limit. I'm a bit more at 300lb and am needing to check and clean my act unit. How does one go about using a "board" to make it safer? Sorry new to all this. Do I use a piece of plywood, 2x4's etc??? Thank you for your help
07-13-2017, 05:08 AM
Okie 265B, at 300# you need to use Plywood regardless of what type of F/R product you have! I also use Pool Float Mats! Be careful and use a Ladder,NOT a Step Ladder! Place a folded towel at the Roof edge to prevent damage to Drip Rail also! Youroo!!
