Old 08-25-2019, 06:15 PM   #1
Safely Removing Tar From Paint
Hi I have a 2017 wolf pup. I have tar on the front of the travel trailer from when they were spraying the roads when I was in the Southwest. Forest River sprayed my trailer paper thin with paint. So I am reluctant to use anything harsh on the paint surface. I have already tried clay bar peanut butter and WD-40 with no success. Any advice on how to Safely remove the tar spray would be greatly appreciated. Thanks, Ken.
KenS999 is offline   Reply With Quote
Old 08-25-2019, 06:21 PM   #2
KyDan's Avatar
Kerosene. or diesel fuel and a soft rag.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32
Old 08-25-2019, 06:52 PM   #3
Stank Bait's Avatar
Naptha or just old style cigarette lighter fluid which is naptha.
2013 Flagstaff 831FKBSS
Stank Bait is offline   Reply With Quote
Old 08-25-2019, 09:45 PM   #4
A32Deuce's Avatar
I use bug and that remover from Turtle Wax.
A32Deuce is online now   Reply With Quote
Old 08-25-2019, 09:59 PM   #5
I made the mistake of using clay bar to remove tar from the front of my trailer. It took the tar off but dulled the gel coat wherever I used the clay.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is online now   Reply With Quote
Old 08-26-2019, 05:40 AM   #6
WD-40 is totally safe and extremely effective at removing tar. I drove my Mojave Sand RAM Rebel on a road being resurfaced and the company doing the work made a mistake and had a literal stream of hot tar flowing across the lane not being worked on when a rain blast hit. I drove down the hill in the rain and did not know anything happened.... until I got home. The lower half of my sand colored truck was pure black and the upper half was heavily speckled. 25 WD-40 cans later.... clean. I would spray and let the fluid "curtain" down the panels and then hit it with the hose as the tar was melting and running. I repeated the spray/hose procedure for a couple hours making sure that body, wheel wells, frame, insides of bumpers and back of running boards were all wetted with WD-40 and dripping black tar.
In the end, I had no damage, I did no scrubbing or manual labor, I just spent a day in the driveway drinking Corona and spraying my beautiful truck.
I recommend WD-40 highly for this job.... and many others!
2017 Ram Rebel 1500 5.7L / 8 Speed, Max Tow 10,160 lb / 1,075 lb payload rating.
2019 F-150 King Ranch 3.5 Eco-Boost 10-speed, 12,800 lb / 1,546 payload.
2020 FR Coachmen Apex Ultra Lite 289TBSS
2019 Quality Trailers 16'x7' 7K GVWR Utility Trailer
2019 Iron Bull 22'x102" 14K GVWR Equipment Trailer
2019 Kawasaki Mule Pro DX W/EPS and Yanmar Diesel 2,000 LB towing and 1,000 payload.
Larry0071 is offline   Reply With Quote
Old 08-26-2019, 12:37 PM   #7
mineral spirits
latner is offline   Reply With Quote
Old 08-26-2019, 12:42 PM   #8
robo44's Avatar
Goof-Off, Goof-Gone; less toxic baby oil, vegetable oil works for me
2019 FR3 33DS Motorhome
Travels California Coast & Beyond
robo44 is offline   Reply With Quote
Old 08-26-2019, 01:17 PM   #9
I've always used good ol gasoline. Just make sure to wax afterwards. Anything that removes tar, is definitely removing wax or any similar paint protection.
Me, the wife, & 2 daughters (9 & 4yrs old)
2019 Palomino Puma QBSS
2015 Silverado LTZ / Z71 w/ many upgrades
GXPWeasel1 is offline   Reply With Quote
Old 08-26-2019, 01:34 PM   #10
Turtle wax bug and tar
I agree. Turtle wax bug and tar remover is amazing.
Gideon is offline   Reply With Quote
Old 08-26-2019, 01:50 PM   #11
Road Tar
I learned this from an individual who made his living painting expensive cars...put a cup of kerosene in a couple gallons of water. With a sponge or teri cloth towel, apply the mixture to the surface, rubbing lightly. Rinse the sponge/towel and wring out, go over the area a second time. With a dry towel, dry the area to a luster. It won't hurt aluminum, fiberglass or decals. You can apply a polish after, or not. Its easy and can be done after every trip.
JimMorrell is offline   Reply With Quote
Old 08-26-2019, 09:07 PM   #12
Tar removal
I also recommend Turtle Wax "Bug & Tar Remover". Have used it for years on vehicles and travel trailers.
Bob2019 is offline   Reply With Quote
Old 08-27-2019, 08:59 AM   #13
^^^^^^ X2
Dave13 is offline   Reply With Quote
Old 08-27-2019, 11:51 AM   #14
Turtle Wax Bug and Tar remover (as others have said).
Use it per the instructions. Not only removes the Tar, but also leaves a shined wax finish. Be sure to wash your RV first. If there are water spots, they will be covered over vs. being removed.
On my Georgetown 31L5 (35') I had LOTS of tar all over due to driving through a freshly 'oiled' road surface.
It took two full bottles of the Turtle Wax Bug and Tar remover to get it off, bu it did all come off.
I carry a bottle of it in my essentials gear for bug removal. Folks in the middle of the country understand that you can run through a swarm of bugs that seriously impair visibility. You just have to stop and clean the windshield.
McCormickJim
2017 GT 31L5
McCormickJim is offline   Reply With Quote
Old 08-27-2019, 12:09 PM   #15
this is the best and most have a can or two around that they can get there hands on.
cfo111 is online now   Reply With Quote
Old 08-27-2019, 12:44 PM   #16
Hello this is the OP. Unfortunately WD-40 did not work for me. I went with the Turtle Wax bug and tar remover spray. Following the instructions on the bottle about 50% of the affected area needed to be retreated a second time in order to effectively remove the tar spots. Thank you to everyone for your input.
IMHO Forest River definitely needs to use a little more paint on their travel trailers. I believe my Walmart bicycle has more.
Ken
Old 08-28-2019, 05:06 PM   #17
Old Engineer
FleckDreher's Avatar
Mineral Spirits,
Cigarette Lighter Fluid,
Charcoal Lighter Fluid,
on a paper towel,
none of these will hurt the paint, plastic, rubber, gel coat, or clear coat.
Wash with soap and water, re-wax the spots.
2019 Dynamax Isata 3 24RW
Smart Car Towed 4 Down
Quote: "When all else fails, read the manual!"
FleckDreher is offline   Reply With Quote
