Old 06-16-2019, 06:26 PM   #1
Sagging plastic. Is this normal?
Hello, I just brought home a 2020 Grey Wolf 23DBH. I was underneath messing with some Jack blocking and noticed that the plastic underneath that must be covering the plumbing sags in a few spots around the edges. Its not loose, more like the spray in insulation is pushing it down.
Anyways, a few pictures say 1,000 words.Click image for larger version
ID:	207532Click image for larger version
NotLost is offline   Reply With Quote
Old 06-16-2019, 06:55 PM   #2
Flybob's Avatar
Not a big deal. Happens sometimes when Coroplast warms up. I would just shoot a little foam in the spaces. If you decide to do this, plan you work as spray foam cans are one use only no matter how hard you try to clean.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-16-2019, 07:00 PM   #3
Thanks for the advice. Its mostly foamed in, there was only a finger sized gap. Is it protected under there if I drove it in the rain? If it will just drain and dry no biggie, but if it's a big sponge...
Old 06-16-2019, 07:04 PM   #4
Flybob's Avatar
I would be more concerned about rodents. You will never get a perfectly waterproof undercarriage.
TST Tire Monitors
2 100W solar panels
Old 06-16-2019, 07:09 PM   #5
Good call, I wasn't even thinking about critters. Will any spray foam work or is there a preferred type. Definitely a one shot thing, my wife wasn't happy when I dripped some in a tub, had to sand it out.
Old 06-16-2019, 07:52 PM   #6
Iwannacamp's Avatar
I would use minimal expanding if it was me.
2017 Puma 297RLSS
Old 06-16-2019, 08:04 PM   #7
Flybob's Avatar
X2 on minimal expanding exterior.
TST Tire Monitors
2 100W solar panels
Old 06-17-2019, 01:09 PM   #8
Would silicon work as well, assuming the gap isn't to i
Old 08-22-2019, 05:42 PM   #9
It's not so much about the driving rain, as it is about mice getting into your trailer from that access hole. Patch it up as soon as you can.
palomini-er is offline   Reply With Quote
Old 09-01-2019, 09:01 PM   #10
I place dabs of Vicks vaporub around my TT. The oder keeps away rodents and other critters like stray cats. Part of my winterizing is to place Irish Spring soap shavings in plastic dishes inside the TT. I discovered this when mice got into all our desks except mine, because I had Halls cough drops in my drawer.
2005 Flagstaff 827fls
RetiredSoldier919 is offline   Reply With Quote
