Old 01-12-2016, 08:48 PM   #1
john5646's Avatar
Salem Hemisphere nose cap
Recently picked up a Salem Hemisphere, travel trailer. they happen to have a dark brown fiberglass front end. So only have 50 moles on this unit, and tow vehicle has already thrown a stone into fiberglass causing a chip. I will repair that... The question is this. What creative ideas have you done or seen to reduce stone chips from roadway?
I wanted to have covers made of material bed tarps are made of in brown and have snaps on them and install them when towing only, not leave on all the time. Something 2'x3' on each side. However my better half is far from sold on that idea. So hoping you all can throw me some ideasClick image for larger version
Name:	ImageUploadedByForest River Forums1452653300.800418.jpg
john5646 is offline   Reply With Quote
Old 01-12-2016, 11:17 PM   #2
Run the hitch style mud/rock deflector. ....
Bartlett is offline   Reply With Quote
Old 01-13-2016, 11:13 PM   #3
I go RV'ing not Camping
jgourlie's Avatar
My heritage glen sister brand to yours has spray on bed liner half way up the front cap. Seems to provide a lot of protection. I am not sure if the dealer put it on or if it came like that from the factory.
Hope that helps,
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 01-14-2016, 07:40 AM   #4
Chewie's Avatar
What touch up paint did you use for the front nose cap? Can't seem to find one locally for a close match. Just something to cover up the rock chips like you said.
I used to have a really nice motorhome
2016 Jeep Wrangler Unlimited
Chewie is offline   Reply With Quote
Old 01-14-2016, 12:32 PM   #5
I would stear clear of covering with any snap on cover while in motion. You will get lots of wear on the gel coat from the cover. We get this a lot in the boating industry from towing with covers on boats.
smorris7 is offline   Reply With Quote
Old 01-14-2016, 02:55 PM   #6
How to protect your trailer?
I wanted to have covers made of material bed tarps are made of in brown and have snaps on them and install them when towing only, not leave on all the time. Something 2'x3' on each side. However my better half is far from sold on that idea. So hoping you all can throw me some ideasAttachment 97731
This is a issue with trailers as the TV tires kick up everything off the road right back and into the trailer, with this said you can a couple of things;
1) get a rock guard tow flap system that installs on the hitch or ball and had two heavy duty rubber flaps that will slow down some of the debris being thrown back.
2) have the front of the trailer sprayed with some kind of protectant, it could be like the motorhomes get, which is a heavy plastic type product, or have it sprayed with a rock guard product like a bed liner type product.
3) look online for the plastic rock guard looks like aluminum you would see on trucks ( can not remember the name of the look) but has the cross hash on it, you can get this product in sheets and glue it on the front of the coach like a lot of companies do.
Hope some of this helps and good luck and Happy Camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 01-14-2016, 05:49 PM   #7
john5646's Avatar
Chewe,
I got a paint code from dealer through forest river, we'll email they sent won't open so 1-15-15 I'll call and get it over phone when I do I'll post it here.
Old 01-14-2016, 08:56 PM   #8
Chewie's Avatar
Chewe,
Old 01-15-2016, 08:32 AM   #9
john5646's Avatar
Chewie
Salem Hemisphere paint code for the front cap is PCP-600 and the formula for it is listed above this is a Dupont Axalta paint.
Name:	ImageUploadedByForest River Forums1452868297.585451.jpg
ID:	97854Click image for larger version
Name:	ImageUploadedByForest River Forums1452868311.209660.jpg
Old 01-15-2016, 07:07 PM   #10
Chewie's Avatar
Chewie
Attachment 97854Attachment 97855
Ok thanks. I tried to google search those paint codes to see if there is a cross for a small bottle of touch up, so far no luck. I was looking for the type you can find at an auto parts store.
salem
